Thread: Position of Jets
    May 2015
    Elburn, il
    16
    Position of Jets
    Looking for some insight on the correct positioning of the water return jets. Initially, i saw some information somewhere that the jets should be angled 45 degrees down. Last year, a pool guy told me that they should be pointing 45 degrees counter clockwise in order to help move the water around the pool and by the skimmer.
    38,524
    Re: Position of Jets
    Please add your pool details to your signature as described HERE as it will help us help you.
    You generally want to create a circular flow so debris will move to the skimmer. You also want then point down a little to mix at depth.
