Thread: Help keeping larger spa clean
    May 2015
    Franklin,tn
    2
    Split from HERE by moderator. jblizzle
    We have a similar problem.. We have a large spa 12 ft by 8 ft. (fiberglass) that has a skimmer that has become nonfunctional. We would like to have a full time vacuum or skimmer that will keep the water clean as we use it as our inground pool. We looked at the Pool Blaster and I know it will work but the Solar Breeze seemed like it would be even better. Unfortunately, not available from the company and not certain if it ever will. This spa is the center of a very nice outdoor living areas and has multiple fountains, lights etc. Any ideas of skimmers or smaller robotics that would do the stairs, walls, and benches as well as the tiles? I suspect that it would have to be a robotic such as a dolphin that was a bit smaller but still very strong and able to take care of business.
    Jun 2015
    Wildomar, California
    423
    Re: Help keeping larger spa clean
    Quote Originally Posted by TCL View Post
    Why does the skimmer not work? The spa must be really dirty with a nasty surface skim line. And, where is the suction at? Main drain or side suction fitting?
    May 2015
    Franklin,tn
    2
    The skimmer does not work due to a leak in the line which is according to the leak detector adjacent to the spa and under the concrete and brick.. He said it might be multiple holes in a flexible pipe. We had hoped not to dig up the hardscape in an attempt to fix the line. Wonder if it is possible to snake a new line through the old line. There are two suctions in the side walls towards the bottom of the spa. Yes, no skimmer means side skim and junk at the bottom especially with the weather we have had and overzealous landscapers who like to blow mulch around.
    Jun 2015
    423
    Sounds like you need a PoolBlaster or an Aquabot. I know Leslies has both
