Thread: Brand new Haywood pump/filter loses suction/outflow every 2 hours or so....
    Jun 2015
    Gorham
    1
    Cool Brand new Haywood pump/filter loses suction/outflow every 2 hours or so....
    Hi there- I just got a used Intex Ultra Frame pool, 16' x 48". The pump that came with it, also Intex, was just not doing much of anything, so I decided to invest in a new sand filter/pump combo. Hayward S144T1540S Pro Series Top-Mount Sand Filter 14-Inch 4-way Valve and 40 GPM Pump
    I got it up and running, and WOW, what a difference! But then.... after a couple of hours, we noticed it wasn't sucking or blowing (sorry, but that's what it seems like) with nearly as much pressure as before. So we unplugged it (sort of a reboot) and plugged it in again. Poof!! Working great again. And then it slowly started declining. We have brand new pipes, brand new sand, using Baquacil for chemicals. Just wondering if this is something that's to be expected, or if it isn't, is there something to do? There don't appear to be any leaks anywhere. Any help is appreciated!! I'm sure I'll have many more questions
    38,524
    Re: Brand new Haywood pump/filter loses suction/outflow every 2 hours or so....
    Welcome to TFP!!!
    What does your water look like?
    FYI, we are not big fans of the Baq method of pool care ... lots of money for sub-par water.
    JoyfulNoise's Avatar
    May 2015
    13,254
    What did you fill the pool with? How did you start up your sand filter? What are the pressure reading on the sand filter (clean pressure at start up versus what your seeing when it slows down)? I believe new sand requires a bit of backwashing to get it cleaned of any fine particles in it. Have you tried backwashing the filter a little to see if that helps?
    Matt
