Thread: Will Alum help to remove Laundry Detergent
    May 2015
    Huntsville, Alabama
    4
    Yesterday so many responded to my use of Arm&Hammer detergent instead of bicarb. Got some great advice as well as some sympathy.
    Today, I am remembering the use of Alum some years ago to help clarify my pool. Could this be used to remove the detergent? I am following the advice to Shock and let time help, however, I am always trying to find the best solution to any problem.
    Thanks so much for your responses. This is the best site I have found for helping each other.
    30,432
    Re: Will Alum help to remove Laundry Detergent
    Alum is essentially a flocculant and we don't like them.
    Sometimes flocs can help and often time flocs give you a bigger mess than you started with.
    It's your call but I would not suggest ANY floc in your pool.
    Mar 2007
    San Rafael, CA USA
    12,082
    Just scoop the foam from the surface of the pool and the rest will dissipate over time. That's how most people handle detergent in the pool. It's not causing any issues and is just a nuisance due to the foaming.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,658
    Dang chem geek.........I wanted to drag over a load of clothes first! As he said, scoop foam and rest will take care of itself with no issues.
