Thread: Taste Borates?
    Oct 2008
    Terre Haute, IN
    51
    Taste Borates?
    I have read numerous threads giving all the positives of borates, any negatives? Anyone that has done it, is there any detectable tastes ( I noticed its hit and miss for salt and SWG levels, what about at 50ppm borates)? Does this mess with anything in the pool as far as negatives due to increasing TDS?
    Apr 2008
    Central Texas
    326
    Re: Taste Borates?
    The only difference I've noticed is that the pool stays crystal clear all the time. 8)
    26,000 Gallon Gunnite IGP
    2 HP Challenger High Head Pump
    60sf Nautilus DE filter
    Polaris 280
    Guest
    Re: Taste Borates?
    Borates had no impact on taste, as far as I could tell in my pool. Nor have any friends or family ever commented on the taste, just on how the water sparkles.
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Re: Taste Borates?
    If you have dogs that drink out of your pool, you might want to break them of that habit if you're going to add borates to your pool. This is generally a non-issue due to the low level of borates used in a pool, but I always mention it when someone asks about the pro's and con's of adding borates, just to make sure that the person asking the question is fully informed, because borates in high enough concentrations can harm your dogs. Again, the low levels used in pools should not harm your dog, but I want to make you aware of the possibility.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Guest
    Re: Taste Borates?
    For that matter, salt, chlorine, algaecides, or any other pool chemical in high enough concentrations can harm pets that drink out of a pool. Best idea is to train the pets NOT to drink out of the pool!
