Results 1 to 7 of 7
Thread: Good News - Got my rails out = Bad News - SWG cell stuck
    Mar 2008
    Central VA
    328
    OK, you guys, good news is that this thread http://www.troublefreepool.com/arrrg...out-t9941.html helped me; I tapped the bolts down and put water in the cups and wiggled and wiggled and wiggled and the rails and ladder finally came out - THANKS!
    So now, I got ready to finish closing my pool, and I wanted to put the "Dummy" or "Spacer" cell in (take the SWG cell out of the line and put in a single 'pass-through' section of pipe, that costs an obscene amount of money but gives you peace of mind).
    SO, I tried and tried and tried, but I could only get one fitting loose on the SWG cell; the black fitting on the other side would not budge.
    I could get one fitting off (hence the water on the concrete), but I did everything I could to twist the other one off (the black arrow shows the fitting; I was turning lefty-loosey and I even put the 2x4 and hammer to it, as shown in the bottom of the photo, but no dice)...
    So what do I do? Is there something else I can do to loosen the recalcitrant fitting?
    thanks!
    Todd
    Pool: 16x36, 16,800 gal., vinyl, sand filter, SWG & AquaCal Heat Pump
    Spa: Hot Springs Sovereign, 355 gal., ozone/ion
    The most helpful tool you'll ever have for your pool:
    http://www.poolcalculator.com/
    Guest
    Re: Good News - Got my rails out = Bad News - SWG cell stuck
    Try a strap wrench.
    Aug 2007
    Eastern Canada
    54
    I agree with Waterbear that a strap wrench will solve this quickly. I bought one this year, and was able to separate all my screw-together fittings with ease, and without scratches.
    I bought the plastic Boa Constrictor model for CDN$9.99, and it was worth every penny!
    Here is a link to the deluxe aluminum model:
    http://www.amazon.com/BOA-BO13010-Co...5633327&sr=1-1
    18X36' 25000 gal Jacuzzi vinyl Inground Pool (1985) with resin sidewalls, newer Jacuzzi 1 hp two-speed pump and sand filter. Raypak propane heater, Rainbow 320 chlorinator (mostly use bleach).
    Softtub 220 portable hot tub.
    Mar 2008
    Central VA
    328
    Thanks waterbear and derekm, I appreciate it!
    I found a strap wrench at my local Lowe's, and I'll give it a shot probably next weekend...daylight just got alot shorter so I probably won't get to it this week. But this looks like it should do the trick (not to mention, it should let me loosen the tops on any peanut butter jars that refuse to cooperate with me! ha!)
    Todd
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    OK, I've got to ask...how do you break loose a fitting with a 2x4 and hammer???
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    The union on an intellichlor has little tabs on it. With the 2x4 resting on one of those tabs on the appropriate side you can give it a tap in the right direction to get it moving. I don't usually use a 2x4, but I use this general method all the time on hot tubs since there's isn't always room to rotate the handle of my channel locks or a strap wrench.
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Ahhhhhh...gotcha. Learn something new every day!
    Intex 8110 SWCG
    "Fear the Schnauz!"
