Thread: High limit Code Error
    Apr 2015
    TX
    32
    I have a Weslo Daybreak spa. I am getting an error code that is either S1 or E1 (display is difficult to read). From what I can tell, it is a high limit fault.
    Here is the deal. Everytime it faults, the spa shuts down and I have to flip the breaker off and on to get it running again. Sometimes it will run for 8 hours; sometimes for 15 minutes. Either way, it is faulting roughly 5 to 12 times a day. So I guess I am gonna have to get in there and fix it. Any ideas where to start?
    14,800 gallons in-ground vinyl. sand filter. 1.5 hp pump
    Jun 2015
    Wildomar, California
    423
    Re: High limit Code Error
    Hi Squib. Without real knowledge of your spa type, consider this. High limits in spas rarely go bad. They are doing their job, detecting water over a set temp. That usually is a flow problem. I suggest you check for a plugged filter, a plugged pump impellor, a closed valve, a suction obstruction, etc. A calcified heating element is a possibility. The high limit could be defective, but more often than not, its doing its job detecting the symptom but not the cause.
    Apr 2015
    TX
    32
    Quote Originally Posted by OldPoolMan View Post
    Thanks. I'll start digging into it.
