Intermatic T104 208-277-Volt DPST 24 Hour Mechanical Time Switch - Intermatic Timer - Amazon.com
My water solar takes over control of the pump motor when the temperature is such that it adds heat to the pool - (Lx220 SOLAR CONTROL SYSTEM). My issue is that whenever the pump is running, my SWG is running and I can't control my chlorine output very well. Cool days it runs longer and over chlorinates, hot days it runs less.
My system - pump and pump timer, solar, and SWG are all hooked up on the 240VAC legs. I'd like to add this timer to control the SWG independently. Is this the right approach with the right equipment?
I hope to make this a project in July if it's doable.
System photos attached:
