Results 1 to 11 of 11
Thread: Losing water through waste pipe
    Jun 2015
    Houston TX
    6
    A few months ago, we were losing water to the waste pipe when then pump was switched on. We changed the spider gasket and that fixed the problem. Our pool has an overflow pipe and after the heavy rain we've experienced in Houston, the overflow pipe was not flowing. I flicked the pump valve (Pentair model SM-20-2) from "filter" to "waste", in hopes of clearing the pipes. When I flicked it back to "filter", water continued to pour out of the waste pipe. I turned the pump off, but water continues to pour out, just more slowly than when the pump was on. This has been going on for more than two hours so it's not looking like it's going to stop, and I can't understand why it's occurring when the pump is off (when we had the spider gasket problem, there was no water loss when the pump was off). Please help!
    Jun 2015
    Houston TX
    6
    Re: Losing water through waste pipe
    Sorry, I'm new to the forum. I have an inground pool, plaster, around 17,500 gallons, chlorine and DE filter.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Welcome to TFP!
    When you say you "flicked the pump valve from "filter" to "waste"", did you turn the pump off while moving the handle?
    When you switch from filter to waste do you turn off the pump or leave it running? That may be what's messing with your gaskets.
    My guess is the filter is at a lower elevation than the pool so with your waste valve stuck open you are draining the pool. You might close any return line valves to stop it for now until you can get the gasket fixed.
    18' x 36' saltwater inground vinyl pool
    Jun 2015
    Houston TX
    6
    Oh, I did not turn the pump off when I switched from filter to waste. Would I have damaged the gasket? The pump is now off but the water is still pouring out through the drain
    The filter is at a higher elevation than the pool.
    SW Indiana
    9,199
    Quote Originally Posted by smgtx View Post
    You may have dislodged the gasket. Only way to tell is to open it up. If your pump is higher than the pool, you can open the pump basket lid and break the siphon that is allowing water to flow out the waste line.
    Jun 2015
    Houston TX
    6
    I also thought opening the pump basket lid might break the siphon, but it did not. Thank you for your patience, I am clearly an idiot for turning the valve when the pump was on. Am trying to open up the valve now.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    not an idiot, learning is messing things up until you get it right, learning usually costs me money
    Jun 2015
    Houston TX
    6
    I opened up the valve and the gasket was indeed dislodged. As I was screwing the top back on, I finally noticed the instruction on the handle "Shut off pump before operating valve"...
    SW Indiana
    9,199
    "Smarter today than you were yesterday." is what I tell myself when I have those learning experiences.
    May 2015
    Mount Cheaha Alabama
    250
    Spider gaskets fail at the most inopportune time. Chlorine eats them up.
    When you find the one you need order another one online and keep in a spot out of the sun with the small tube of clear waterproof silicone.
    30k in ground vinyl lined pool surrounded by decking in the woods.
    Hayward sand filter circa mid 80's
    If there is a way to do things less expensively and yield a superior product I am all ears
