Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: TFP/BBB and that is all???
    JamesR's Avatar
    May 2015
    Nazareth/PA
    74
    Doing my best to get this BBB thing correct for my pool this year. Very helpful site here and I learned a lot about CYA/Chlorine relationship. Also learned a bit about the Calcium saturation index and ll of the little things that affect it, (pH, TA, CH....)
    One question though, do you folks never add a weekly algecide like ALL-60 or "Pool Perfect/Phos free" or monthly does of scale/stain free? No weekly maintenance products?
    28K gallon, raised beam, plaster/ceramic color quartz with attached spa. TF-100 test kit
    Hayward 1.5HP super pump, DE4800 DE filter, Hayward inline chlorinator w/3" tabs (off)
    Pool: 2 floor drains, 2 skimmers, 3 floor returns, 2 wall returns, 3.5' deep > 8' deep
    Spa: 2 floor drains, 4 jet returns
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: TFP/BBB and that is all???
    I never add algesides or phosfree now that I have TFP there is No need for it.
    I do unfortunately still add scale free. The reason is my CH is very high. Don't have access to different water to bring it down. I tried going without the scale free after my SLAM and my SWG cell quickly scaled bad. I cleaned my cell a week ago and added scale free and not a sign of scale or calcium build up on cell at all.
    Please note that this is my choice and not a recomended additive per TFP.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Never.
    In five years my pool has had nothing but bleach, muriatic acid, and trichlor pucks added to it. The pucks were when I was out of town. My fill water is naturally hard, so I've never needed to raise pH, TA, or CH. Never had cloudy water, never turned green, never closed for the winter. We really don't have winter in SoCal.
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    nope...bleach daily. acid on an as needed basis (3-4 x a season). never green.
    27' AG 18K Gallons ~ Cartridge Filter ~ Pentair 1.5 HP Pump
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Only my second full year of TFP and I've only added bleach and muriatic acid during regular maintenance. I have high TA fill water so never any need to add baking soda. No weekly shocks, no algaecide, no pho$free, no magic bullets, no problems... other than lots of maple whirlygig seeds this year.
    Isolated Spa - 345 Gallons
    JamesR's Avatar
    May 2015
    Nazareth/PA
    74
    Wow, if that method works up here in the NE, that should save me some $$$
    I may pick your brains come closing time before fall/winter arrives. I usually go heavy on the algecide right before the safety cover goes on. It is mesh and all sorts of stuff get in there over 8 months.
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Quote Originally Posted by JamesR View Post
    Follow the closing/opening recommendations on this forum and you'll be amazed at how easy it can be.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    Donldson's Avatar
    NW Ohio
    2,917
    Never.
    I pretty much am in the same water situation as Richard, except I do get Winter, so I close. In 2009 I added a Polyquat algaecide at closing (I was still new and thought I still needed it) but since then I have not added anything but liquid chlorine, acid, and pucks on occasion. I have opened to perfectly clear water every year since. YMMV because of the mesh cover, but plenty of experience in that on the forum so feel free to ask around.
    One reason (among many) that TFP now calls the method taught here TFPC instead of BBB is to avoid people running out to buy borax and baking soda and dumping it in to their pool. It is a pool care technique, as well as a philosophy. You test, you add only what is needed, and your entire pool care vision changes. Suddenly the pools that people call clear look cloudy to you. You really notice the chlorine smell of other pools because your pool doesn't have that (even thought your FC is probably double theirs). The shimmer of your water will almost blind you on a sunny day but you just throw on some sunglasses and smile.
    Oh yeah, and the significant savings helps too (my upkeep is about 1/5th the previous cost, but it varies).
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    JamesR's Avatar
    May 2015
    Nazareth/PA
    74
    Sounds great! Looking forward to see how this season goes. I will forgo the weekly algecide and other maintenance additives I have been using for 15 years in this pool and see how it goes. I am armed with the TF-100 kit and splurged for the power magnetic stirrer.
    38,524
    Sounds like you certainly have the right tools for the job ... and an open-minded attitude
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,197
    Welcome to TFP!!
    We have folks all over PA using the system with great results. 15 years of habits are hard to break. You weekly algecide didn't contain copper, did it?
    Also, to give TFP a fair shake can you please verify the pool doesn't have anything hiding in it by conducting an Overnight FC Loss Test (OCLT). This is usually best conducted with an elevated FC, above 5 but closer to 10 helps.
    Support the site
    Feb 2014
    Central Minnesota
    5,080
    The caveat to us folks that close our pools for the winter is that you MUST open early and close late. If you wait until June to open your pool, you'll have a problem. The pool should be opened before the water temp reaches 60 degrees and should be closed in the fall once the temperature is consistently below 60 degrees. 60 degrees is a good rule of thumb for algae growth. They will only grow/reproduce very slowly at temperatures 60 and below, much faster above 60 degrees. This is why we open early, close late. And at a lower cost that pool store methods, it's no big deal to maintain the pool for a few extra weeks. Especially at colder temperatures where FC usage is generally lower.
    whataboy's Avatar
    Jan 2015
    Lewisville,Texas
    53
    Yep, my first season with new plaster a month ago and totally doing BBB method. Pool looks like diamonds dancing on sparkling water. Was in pool store yesterday to get reagent I was out of and couldn't believe how many people were in there buying all those high dollar chemicals. One employee ask me how my pool was looking and I told him awesome cause I use the BBB method. He looked at me with a frown. Maybe he didn't want other customers to hear and would potentially start losing sales..haha
    Rick T.
    12,000 gallon IG Kidney shape,gunite,white plaster w/25% blue quartz (Chlorine)
    Jandy LED Multi-color pool light, ,Pentair VS Pump,Pentair FNS 48 DE Filter,Polaris 280 Cleaner
    TF-100 test kit, Taylor K-2006 test kit, Speed Stir, BBB Method, PoolMath, TFPC
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    I am on well with iron, so the only thing other than liquid chlorine and muriatic acid I use is Metal Magic to avoid metal staining.
    If you've historically treated with Metal magic or Jack's magic to sequester metals, that's the only product you'd need to continue
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    May 2015
    South Park, PA
    39
    Opened in mid/late April this year (first year using TFP methodology). Nothing but bleach so far. Pool looks great.
    30,000 gal inground (20 ft. x 40 ft. w/ deep end), vinyl liner, Pentair Clear & Clear 420 cartridge filter, single speed 1.5 HP Pentair Whisperflow pump, heat pump, SunTouch controller
    JamesR's Avatar
    May 2015
    Nazareth/PA
    74
    Quote Originally Posted by tim5055 View Post
    Welcome to TFP!!
    No copper as far as I ever knew,...SunGuard algecide-60
    I will do the OCLT either tonight or tomorrow night weather depending. Got big storms rolling through.
    May 2014
    Franklin, NC
    9,197
    Looks like a variant of PolyQuat 60. It is used by many here when closing for the winter. No copper, which is good.
    Support the site
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    I have a solid safety cover. Closed at the end of October per the closing methods on here, opened at the end of March, and still had FC of 6. Never add any algaecide or any pool store magic bullets. Follow the methods here, and you'll be amazed at the clarity of your pool compared to what people normally consider clear pools. Literally looks like diamonds shimmering on a sunny day. It's awesome.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Well, just to jump in here. Starting our 4th swim season with the pool. Never "shocked" or added anything to our pool other than bleach, salt, muriatic acid, borax and epsom salt. Pool water has been crystal clear the entire time.
  20. Back To Top    #20
    Ellington, CT
    262
    Well it does and it will save you moeny. This is my third year following TFP method and since I have never...
    1) added algecide
    2) never needed to "shock" or for that mater SLAM my poople
    3) opened to a swamp
    As for opening and closing, I now close in early October and although I don't take my cover off until early May I now set up-my pump and get the water circulating in early April adding chlorine as needed.
    30,000 gal, 20 x 40 ft vinyl, IG, installed 2006
    1 HP WhisperFlo pump, 60 sqft Pentair Quad D.E., Liquidator(8 gallon) with 3/8 upgrade, AquaVac TigerShark cleaning robot
    TFTestkits TF-100 with SpeedStir, WS
    A proud practitioner of TFP since 2013
