Results 1 to 13 of 13
Thread: Disconnecting Automatic Chlorinator
    May 2015
    Mississauga
    29
    So I have a Hayward Automatic Chlorinator which I want to disconnect. It is currently plumbed into my one of my main pipes (PVC). How can I disconnect it and plug up the hole? Is there another method? I want to use liquid chlorine only and I want to stop with the chlorinator. Currently I have it off but I am not sure if that is enough. Any help would be appreciated.
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Re: Disconnecting Automatic Chlorinator
    can you not just cut it out and put in new pvc with some slip couplers? should be about $3 worth of materials from home depot.
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Pics are invaluable!
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jun 2014
    15,008
    Ziggygal, I also have a Hayward in-line chlorinator that I no longer use since I follow TFP. I simply leave the chlorinator empty. It doesn't hurt anything, and I don't really see a need for you to cut into your lines just to remove it. If anything, you may use it on a VERY rare occasion .. for example, you know your CYA is at its low range and you go out of tow for a while. You cold drop a puck or two in there and know you are getting some chlorination until you get back. But really, there's no need to remove it. Leave it as a reminder of how much money you are saving by not filling it up.
    May 2015
    Mississauga
    29
    Hi Texas Splash.
    So I just leave it empty and off? That is really enough? That would save me so much trouble!
    11.5K gal, IG vinyl, 3/4 HP Hayward Pump, Hayward sand filter, Hayward Chlorinator (Turned Off), Raypak Heater, Taylor FAS-DPD K2006C T/K
    Jun 2014
    15,008
    All of this is assuming when you say "automatic" chlorinator, it is the same as an "in-line" chlorinator. Not sure if there's a difference.
    If you click on the "My Pool" link in my signature, you'll see my in-line chlorinator. If we have the same thing, then yes, you can just leave it empty. If you have something different than mine, post back and we'll re-address your issue more specifically.
    May 2015
    Mississauga
    29
    Hi,
    I have a picture of my chlorinator.
    You can see it next to my pump on the floor. It is connected to the pvc pipe going into the pump with small tubing. Again, is it enough to shut it off and keep it empty?
    Thanks again!
    Jun 2014
    15,008
    Oh, that IS different than mine. I can't see the need to go out of your way to remove it, but honestly I'd feel better if someone else would chime-in who perhaps has owned on of their own. Yet something else I can learn from today as well.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Just leave it there and turn it off. From the photos it has a small tube feeding it from just after the pump and then injects the chlorinated water somewhere down the line I can't see.
    Remember, TFP isn't "against" pucks. You just need to understand what they add and control it. I am a prime example. I started last year with CYA 200+. I have now worked it down to 40, but I want it at 50. I'm holding off for a few weeks until I go out of town and I'm going to supplement my Stenner Pump with pucks to bring the CYA back to the 50 I want.
    Support the site
    May 2015
    Mississauga
    29
    Thanks tim5055! I prefer the liquid chlorine but can use the chlorinator for times when I am not around like vacation. I would rather keep it plumbed in just for these types of situations. Thanks!
    Jun 2014
    15,008
    Apr 2015
    South Central PA
    297
    I have the same Hayward auto chlorinator. I just removed the pucks and put it on a low setting for a few days to clear it out, then turned it off.
    20000 gallon vinyl liner in ground pool
    16' X 34' rectangular diving pool
    Hayward Pro Grid DE Filter
    Hayward 1 hp Super Pump
    TF-100 Test Kit Stenner 45MPHP10
    May 2015
    Mississauga
    29
    Thanks 440dodge440!! I did just that last night!! This forum is awesome!
