Thread: Pump broken, New one incoming, Chorinate?
    May 2011
    Wichita, KS
    38
    Well, I filled the pool, removed the cover, pulled out my winter plumbing and went to fire up the pump. Wa wa waaaahhh, no worky. The replacement is coming on Wednesday. My water is getting pretty cloudy, should I chlorinate even though I can't really circulate? I guess I could stir it manually. Thoughts? Feelings? Comments?
    Thanks in advance.
    Filter: sta-rite cartridge
    pool: In-ground vinyl
    pump: ?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: Pump broken, New one incoming, Chorinate?
    Yes, chlorinate and then brush well to really get it mixed.
    May 2011
    Wichita, KS
    38
    Thanks Richard, I'll start shocking it tonight.
    pump: ?
    Richard320's Avatar
    Jan 2010
    19,051
    Quote Originally Posted by Earl42 View Post
    No, just add what it needs to maintain normal levels. You risk bleaching your liner by going too high without constant circulation.
    May 2011
    Wichita, KS
    38
    Got it. Glad I checked back. Thanks again.
    pump: ?
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,593
    You can use a straw broom to help mix the water or get in and walk around to make it move. If you can get your hands on a sub. pump you can also put that in to move the water.
    Kim
