Thread: Low Amp Warning on AutoPilot Cell
    Jun 2015
    Jacksonville, fl
    1
    Please help...I have an Auto Pilot salt system, 15,000 gallon pool. It has been reading "low amps=check cell?". Salt levels are at 3400, so I first replaced power cord to cell, no luck. I just replaced the cell, no luck. When I test system not running it reads 7V .7A, running 6V .6A then 1V .2A then 0v .2A. That is checking one time after another. Any suggestions?
    JoshU's Avatar
    New Orleans, LA
    542
    Re: Low Amp Warning on AutoPilot Cell
    What is the model # of the control unit (i.e. DIG-220, ST-220, 75003)?
    What is the age of the control unit?
    What was the purifier % level set to when you saw those volt and amp results? Any time a unit is tested it should be at 100% purifier level and/or "boost" mode for a minimum of 60 seconds to ensure that you're seeing proper test results. Some newer versions of the digital models may have more specific instructions as well. Once I know more about your installation I can better advise.
    Thank you,
    Josh
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
