Results 1 to 9 of 9
Thread: Oval pool walls leaning out
    Jun 2014
    Grand Rapids, MI
    6
    Question Oval pool walls leaning out
    We had a 15x30 oval pool installed last summer.
    One side of the pool the wall leans outward several inches.
    It's the kind without buttresses.
    Is this normal or should I be worried?
    The installer is no where to be found so I'm not even sure where to go for help.
    Casey's Avatar
    SW PA
    10,461
    Re: Oval pool walls leaning out
    Doesn't sound right at all. Can you post pics?
    Jun 2014
    Grand Rapids, MI
    6
    I will try and add a few more
    Jun 2014
    Grand Rapids, MI
    6
    Can't seem to figure out how to load more pics
    lovestoswim's Avatar
    May 2015
    Milford, Ohio
    102
    Quote Originally Posted by worried View Post
    That looks normal but I am by no means an expert. With an oval pool your walls will lean out some in between each of your uprights on the straight sides.
    24,000 gallon, 21x43 Oval Wilbur AGP installed June 2015. 10'X24' deck. 2hp Aqua Pro Cartridge Filter. Using TFP method.
    Jun 2014
    Grand Rapids, MI
    6
    thank you for your input. What has me worried is the post themselves are what's leaning. On the ends a few tilt inwards and on the long sides the posts lean outwards.
    I guess my main concern is if it's safe.
    Casey's Avatar
    SW PA
    10,461
    How's the other side look?
    Feb 2015
    Bardstown KY
    139
    If the bottom of the post is in farther than the top, that is a problem that NEEDS to be addressed. I speak from experience - we have just been there and done that SEVERAL times.
    Take a level out and check all of the posts for plumb. Don't go by appearance only - that can be deceiving. If some are leaning out then your installer needs to correct it.
    Duh - sorry. I posted before I realized I had your pool confused with someone else's. Yes I would be concerned about that. I am very far from an expert, but many real experts have told me this is true as well.
    27k gallon 33' round, partially buried 22" Sandman sand filter, 1.5hp 2 speed TidalWave pump, Pentair 'Lil Shark with leaf canister, TF-100 Test Kit
    Aug 2015
    lake city pa
    1
    wow that is the same thing I was concerned about ours looks the same but on both side with the same post it was just installed this weekend should we call the installer to have it checked out
