Results 1 to 12 of 12
Thread: brand new liner starting over
    just installed a brand new liner and filled the pool. The PH is good at 7.2 and I have shocked the pool. Test show no type of chlorine at all. Before this I always used the 3" tablets in a in-line chlorinator, but my pool water never seemed crystal clear. At this moment it is clear and I need to know what is the next step I need to do to keep it clear. Thanks for any suggestions.
    Peggy Bookout
    Chesterfield, Virginia
    above ground 27" pool 52 " tall
    in line chlorinater
    Hayward 1 1/2 hp pump with sand filter
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,429
    Re: brand new liner starting over
    Can you tell us what the name of the shock product used was and how much of it you used? Depending on your answer you may need to add CYA, also known as stabilizer or conditioner. Since some shock products contain CYA we need to know how much you have added to determine if you need more. You will also need to add chlorine. We prefer plain, unscented 8% bleach from the grocery store. It does not add CYA or calcium to the pool, both of which may be problematic over time. We do not recommend chlorine tablets as they do not release chlorine quickly enough and they add CYA to the water. It is also recommended you have a FAS/DPD based test kit, so that you are able to test the water yourself and use those results to dose your pool.
    Love TFP? Become a
    TFP Supporter!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,517
    Welcome to TFP! Congrats on the new liner.
    Get one of the Recommended Test Kits, I use the TF100 from tftestkits.net.
    Here are some of my fave Pool School articles about how we maintain pools TFP-style.
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals and how to add them.
    Use PoolMath to figure out how much to add.
    thank you for the information. So you recommend using household bleach all summer instead of those tablets that go in the in line chlorinator? I am thinking they are what is making the pool in previous years not look clear. How much bleach should I use and how often. Also I did put a gallon in it Saturday and checked it that evening and it still does not show any chlorine levels at all.
    Peggy Bookout
    in line chlorinater
    I bought the 3" "In the Swim" tablets. ( it states on the container slow dissolving) I actually ordered them on line last year. I would fill up the in line chlorinator and turn the setting knob on 1/2 to 3/4 open depending on what the test read. It always seemed to keep the level at what was recommended on the test strip but the water never was crystal clear.
    Peggy Bookout
    in line chlorinater
    Jul 2009
    Houston, Texas
    9,429
    We need to see a complete set of test results to be able to tell you what your pool needs. I asked about the type of shock product used in order to help determine your CYA level. It is important to know your CYA level so you will know how much chlorine you need to add. Most of us at TFP add liquid chlorine to our pools every day or two.
    You will not be able to keep your pool clear with chlorine tablets alone. Chlorine tablets are designed to help maintain a low residual between weekly doses of pool shock. We do not recommend using pool shock, which is one of the reasons we do not recommend tablets.
    Love TFP? Become a
    TFP Supporter!
    I have ordered a recommended test kit, but for now I only have test strips. It shows the CYA is way low. It is the color that is the lowest on the strip. So I am using bleach and its still clear, but I read on this site hen I first opened it last weekend, to get the ph correct and then shock it. But you are saying if I use bleach , do not use shock. Will the bleach alone keep it clear and healthy? I am showing FC is 0, ph around 7.2, alk is a little low on test strip, hardness is a little low and CYA is very low. . I expect my test kit today or tomorrow so I can get a true reading.
    Peggy Bookout
    in line chlorinater
    DFW, TX
    24,517
    The problem is that you see a number on that test strip and think that it should mean something. But, it doesn't. Or that it is better than no test at all. But, it isn't. The PH test might say PH is 7.2. And you might be tempted to add something to change it. But, it might really be 7.8 and you might create a problem that doesn't exist now.
    We can't wait to see some good test results.
    I will hopefully get test kit today and will post the results. I appreciate all the help. I am no pool expert even though we have had the pool now for 20 years. Just put in a new liner and I want to start off right and keep it clear. I was never bad but then again in my opinion it was never really clear like it is at the moment. And of course I called a reputable pool place today and they said on no, we don't recommend using bleach. It will fade everything. I know they want to sell their product.
    Peggy Bookout
    in line chlorinater
    Skitch's Avatar
    May 2015
    Athens, Georgia
    112
    I find it hilarious that pool stores wouldn't recommend using bleach, which is just nothing more than liquid chlorine.
    Get a test kit and send your pool store a Christmas card. It's much less expensive.
    18,400 gallon 28' round above ground pool sand filter 2013 K-2006 2014 new Hayward pump 2018
    My pool turned green the second year, K-2006 saved me, Trouble Free Pool set me free
    Skitch, I thought the very same thing. The ingredients in bleach is the same as the chlorine tablets. So if one will fade everything out, the other will also in large doses. Ok got my test kit. Chlorine test came in between 2 and 3. PH test came in ideal at 7.6 and alkalinity I am still trying to figure out but I think its around 80. I have never used this type of kit, always those strips. So I am using bleach about 20 to 30 oz. every two days and so far the pool is clear. So does it sound like I am doing it ok, or do you think there is something else I need to do. We have had rain for past two days and calling for more tomorrow but pool is clear. AGAIN, I appreciate everyones advice and help.
    Peggy Bookout
    in line chlorinater
    lefty51's Avatar
    May 2015
    East of Royals country western MO
    451
    Hi bassingal, welcome to TFPC. As pooldv stated above, It is best to read the ABC's of how to do things right. Also at the top of the page you will see pool math. It is a calculator that will tell you exactly what and how much to add to keep your pool perfectly healthy. Just punch in the numbers and away you go. If you have any problems using it or just getting started with it, there are any number of people here who will help you with it or any other questions you have. These people just LOVE to see clean and sparkling pools. You need to run the full set of tests and post them here and the answers will come flying back at you
    FC
    CC
    PH
    TA
    CYA
    CH
    These are the numbers they and you will need to get going
    Si -central Mo. 32' x 16' -- 3'4" to 6' deep Vinyl liner - 16,500 Gals : Triton II filter -Duraglass 2 hp pump - 1 speed : SI-30 salt generator
    TF-100 with speedstir
