Thread: Cleaning pool pump lid? Recommendations?
    Apr 2015
    Visalia CA
    30
    I'm assuming I'll just pick up plast-x. Anyone other ideas? Went to the pool store and they were $50, knew not to buy, but still $22 on Amazon is pricey.
    Jeff
    30' x 17' plaster pool 13.5k gallons (roughly), The Pool Cleaner (two wheel), Taylor k-2006, Pentair WhisperFlo 1.0hp, Purex triton WhisperFlo .5 hp (no idea why there's two pumps)
    30,432
    Re: Cleaning pool pump lid? Recommendations?
    What part of it needs cleaning????
    Apr 2015
    Visalia CA
    30
    The clear part. Can't see inside.
    Jeff
    May 2015
    Mount Cheaha Alabama
    250
    You can try wet sanding similar to car headlight restoration.
    wet the surface with windex and rub toothpaste on it. Really bad oxidation requires sand paper in stages to ultra-fine
    30k in ground vinyl lined pool surrounded by decking in the woods.
    Hayward sand filter circa mid 80's
    If there is a way to do things less expensively and yield a superior product I am all ears
