Thread: Pool Robotic Cleaner Issue - iRobot Verro 500
    Current state -
    Power works, appears that Pump motor works (propellor works) when in pool, but cleaner doesn't move. Manually try to move wheels, but very hard to move them manually. Removed side panels, drive belts look good.
    My feeling is that the drive motor is pooched.
    Questions - Can the drive motor be replaced independent of the Pump motor? What is the situation with parts for iRobot.
    We inherited this unit from previous owners. Worked only one season, then last year it stopped working.
    Any suggestions?
    Concrete Inground, 20x40, 35,600 gal,Hayward pump/Sand Filter, Aquarite T-15
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Pool Robotic Cleaner Issue - iRobot Verro 500
    Welcome to TFP!
    I can't say, but there has been very little if any conversation about these units here that I have seen. Sorry I don't have more, perhaps someone else will.
    Essential Links:
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    I think the iR 500 is made by Aquatron and looks like it's still sold by Costco in Ca. Costco has great return policy here in US,not sure about Ca, but without receipt even tougher? Maybe not?
    A Google search pull up a bunch of sites for parts
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    Jun 2014
    Mono/Ontario/Canada
    24
    Costco is great here as well but you need to have bought the unit or previous owner would have to return....receipt not always required but they can check to see if you bought it based on your membership
