Thread: 2 speed pump question
    Hi all,
    I replaced 2 speed Pentair whisperflo pump last year. The problem is when i use the low speed, pump volute (basket) will have more air bubbles inside than the high speed. When i use the low speed for more hours and when i switch back to high speed, i see my return line have air bubbles out to the pool. Is this normal? I don't see any leak on the pump.
    - NY Albany ~27000 water
    - In ground Vinyl 18' X 40' X 8' Deep Curved Roman End
    - Pentiar TA 60 Sand Filter
    - Pentair WhisperFlo 1HP Energy Efficient Full-Rated 2-Speed
    - 250K BTU Nat/Elec. Heater
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: 2 speed pump question
    Yes. It happens with mine. it's no big deal.
    so is there any problem if i keep running the low speed for few days without run the high speed to blow the air bubbles out?
    Apr 2011
    Murrieta, CA
    2,360
    No problem.
    Dec 2009
    Central Massachusetts
    2,690
    My 2 speed on low does that too. not a big deal
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
