Thread: NewBee Hello from Watts Bar Lake in Ten Mile, TN
    May 2015
    Ten Mile, TN
    74
    Just bought a 24 ft above ground - which gets installed Tuesday (weather permitting). We used to have a cheapy Intex 22 ft pool and it slowly fell apart. We ran it both with chlorine and with dilute saltwater and had no problems with chemistry.....just the physical aspects of the pool.
    But after a couple of years of using indicator test strips, I just bought a good Taylor test kit (I'm a Chemical Eng. and should have done this a while back).
    We had a 21 ft solar cover which I hope will work OK on a 24 ft pool
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,015
    Re: NewBee Hello from Watts Bar Lake in Ten Mile, TN
    Hi dlaslo,
    Welcome to TFP!
    Divin Dave,
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,198
    Welcome to TFP!!
    Support the site
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to the forum!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    LOL @ NewBee, welcome to TFP, congrats on the new pool.
