Thread: SWG BOOST Mode
    TroyB's Avatar
    Oct 2008
    Houston, TX
    39
    SWG BOOST Mode
    My pool has a BOOST mode on the SWG that produces 100% chlorine generation for 24 hrs.
    In a couple of weeks, I have having a pool party with a heavy swimming load. How should I program my BOOST?
    1. 24 hrs. prior to my party?
    2. 12 hrs. prior to my party, so that the middle of my BOOST mode is during the party?
    3. After my party?
    Thanks in advance for your help.
    - 25K Gallons, Jandy AquaPure Model Pure1400 SWG w/ AquaLink RS PDA, Jandy LXi Heater Model 400
    - Jandy CV460 Cartridge Filters
    - IG Plaster Pool w/ rock waterfall & weeping walls, Elevated spill-over spa
    - 2 X Jandy Stealth SHPM2.5 pumps (one for pool, one for waterfall), Pool Pump ~ 100 GPM in pool mode
    - UltraPure UPP25 Ozone Generator, Polaris 280 w/ Polaris Halcyon booster pump
    30,413
    Re: SWG BOOST Mode
    Well, this is probably not the answer you're looking for but I wouldn't use it.
    Make sure your FC is correct or just a little high prior to the party and have fun.
    Then, after the party, test and calculate enough liquid chlorine or bleach to bring it back up to your pre-party normal level.
    New2Me's Avatar
    Jun 2008
    SW Indiana
    322
    Re: SWG BOOST Mode
    1. Depends on HOW much CL it makes in 24 hrs.
    2. Would you party like to swim in high CL water?
    Think of a SWG as a bleach jug with a small hole, you can get all of the bleach in the world, but it has to come out of that hole, which limits the rate you can add it in. This is why most people don't SHOCK with a SWG, it takes too long(plus it wears out your cell faster.) Long term maintenance of stable Cl is what they excel at. Have your party, then shock with bleach if your testing shows CC and low CL, otherwise I'd leave it alone. If you really want to use the BOOST, I would start it when people get in, some SWG do say that people should NOT be in the water when it is running, but that is mainly for the makers CYA, and I don't mean stabilizer.
    22 x 40 IG vinyl lined, 23,570 gal.
    1 hp. Pac-Fab Challenger pump 300# sand filter
    Intex 8110 SWG, Hayward CL220 offline feeder
    Hayward 250K Btu gas heater
    Aquabots
    TroyB's Avatar
    Oct 2008
    Houston, TX
    39
    Re: SWG BOOST Mode
    Quote Originally Posted by New2Me
    Now that's funny.
