Thread: Acid Washing a D E Filter
    May 2015
    Kings Park
    2
    My de filter has not been acid washed in a few years. Do I need to remove the grids from the filter, or can I just fill the filter with the acid cleaner?
    Thanks all
    Slats
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Re: Acid Washing a D E Filter
    You must clean the grids with dishwasher powder or tsp first. Then soak the grids in a the acid solution after all the previous solution has been hosed off. Do not soak them in the filter body. Use a plastic tub to soak them.
    Love TFP? Become a
    TFP Supporter!
    May 2015
    Kings Park
    2
    Thank you for the info. The issue I have is the pool company who closed my pool in the fall glued the grid manifold into the filter body. I would have to crack the pvc tube off and replace it in order to get the grids out. What would happen if I soaked the grids in the filter body? Thanks again
    Slats
    38,520
    Are you sure it is glued and the manifold is not just stuck on the standpipe o-ring?
    Can you post up pictures?
    Take a look at DE Filter Cleaning Tutorial
    Are you sure that the manifold is glued in? Sometimes they're just hard to get off of the standpipe. If it's really glued in, I think that the standpipe is just 2" pvc pipe. You could cut the pipe to get the grids out and then use a 2" schedule 40 pvc coupling the put it back together. Just be sure to get the height of the standpipe back to its original length. Once you get the grids apart, hose them down. That's usually enough. If they need more than that, it's probably time for new grids. You could soak them in tsp. Acid is rarely needed and should be avoided as much as possible.
    Support the site
    Update: The standpipe is 2" pvc. If the manifold really is glued, you can cut the pipe and reconnect it with a regular schedule 40 pvc coupling. A few tips:
    1) If you do cut the pipe, measure the height of the manifold before cutting the pipe and make sure the height is exactly the same when reinstalling. The coupling will add about a 1/4", so you would have to cut out about that much to avoid the manifold being too high.
    2) When cutting the pipe, put something between the pipe and grids to avoid cutting the grids.
    Support the site
