Thread: Inground spa fittings question ..
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Anybody know a good place to get these, They keep popping off!!!!
    Also is there any new style that can be made to retrofit these ( kinda like the ones on fiberglass spas )
    Thanks for any info !!!
    Sean Hannon
    30,000 Gallons gunite pool Coated by Fibertech
    Hayward Pro Grid 72 / Hayward multiport
    Circupool V3 VS pump
    CirCupool SWG RJ 60, 400.000 btu raypak , Built in SPA
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    That looks like a regular return eyeball fitting. Or 2/3 of it. The last piece screws into the return pipe in the wall. Is the ring broken or something? When you screw it on it should stay put. Any pool store should have them. Can't help with the last question. I know they make different size holes in them, but I don't know if that's what you mean.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Re: Inground spa fittings question ..
    They are real hard to screw on due the outer part of the ring hitting the spa surface .
    I had my entire pool and spa fibertech coated and i guess they built it up a little to high around the jets.
    Was maybe trying to find a jet that would screw in the existing hole , but maybe a adjustable one with different spray patterns ??
    Sean Hannon
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Hit Google up for directional return fittings or eyeball return fittings. Maybe they make more kinds than I have seen. I know they make some that go way off to the side, then the different size eyeball ones. If you take the remaining piece out, you can put the three pieces together and screw it all in as one piece. That may be easier than trying to do the ring by itself.
