Thread: Iowa above ground pool
    May 2015
    Homestead, Iowa
    1
    So glad I found this site. I am in the beginning phase of pool ownership. My earthmover is coming this week to grate the ground, pour sand, level and pack it so I can set up my pool. I have watched numerous youtube videos and the videos that came with my pool regarding set up. Any input is appreciated!
    Bestway 18 x 9 x 48" above ground pool, steel frame, bestway sand filter
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: Iowa above ground pool
    Hi, welcome to TFP! If this is your first time caring for a pool please read ABCs of pool water chemistry . It will help you understand how to care for your pool water. I would also like to suggest an investment in a high quality FAS/DPD test kit, such as a Taylor K2006 or TF 100 so you will not have to be dependent on pool store testing services. Pool stores provide testing services because they boost sales based on the results. The problem is those results are often inconsistent or in error. When you conduct your own water tests you know the same person is performing the same test using the same method time after time. This will yield consistent, reliable results.
    We also have a wonderful tool on our site called PoolMath . You can plug in your test results and your target levels and it will tell you how much chemical you need to reach your desired result.
    Best of luck with your new pool and feel free to ask questions and post pictures. We love pictures!
    Love TFP? Become a
    TFP Supporter!
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to TFP! +1 to the advice zea3 gave you.
