Thread: Cloudy water after 4 days of filtering.
    Sep 2014
    Los Altos, CA
    29
    I also have a cloudy pool because I have been using Calcium Hypochlorite to chlorinate the pool due to high CYA levels already present. My sand filter does not do a good or quick job of filtering out the calcium component. I have gone over to liquid chlorine exclusively for the last two weeks and my pool is getting clearer, slowly. My sand filter starts with a reading of about 25 and rises to about 30 before backwashing. I am in the California water shortage so I cannot replace the water to reduce CYA. Also, I only run my filter for a few hours a day so it takes time to clear the cloud.
    Moderator comment: This post was separated out from this thread: Cloudy water after 4 days of filtering.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Cloudy water after 4 days of filtering.
    Good move on going to liquid bleach for chlorine.
    It will take time to filter out the calcium from the cal-hypo. Same thing happened to me when I used Cal-Hypo for "shocking" before I learned about TFP. It will eventually clear. If you want it to clear faster, increase the pump run time a couple of hours a day until it does clear.
