Results 1 to 7 of 7
Thread: Calcium Hardness
    Calcium Hardness
    What is the most cost effective way to increase calcium hardness? We are getting a lot of rain here in Houston and it been getting expensive to maintain the proper calcium hardness levels (250-350).
    I live in the Albany NY area. The size of my pool is 24,000 gallons. The pool is an In-Ground rectangular Double Roman with a vinyl liner. I am using a Taylor K-2006 water testing kit. I have a DE filter. I have a regular chlorine pool. The pool cleaner is a 2017 Dolphin Premier Robotic In-Ground pool cleaner.
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    Re: Calcium Hardness
    I am in the same boat. I just added 5 pounds and it brought me from 210 to 250. Had to add a lot of CYA also. You can purchase calcium increaser at Walmart. Below is a link to Amazon for the same thing. My wife said Walmart was the cheapest she found.
    Amazon.com: Pool Mate 1-2808B Calcium Increaser for Swimming Pools, 8-Pound: Patio, Lawn Garden
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Lowe's sell a 50lb bag of calcium chloride for $ 18.97. This seems to be a much more cost effective approach to increasing calcium levels. Do you know if it is OK to use this product?
    Bob_Funk's Avatar
    May 2009
    Seattle-It really rains all the time
    113
    Morton sell it as ice melter but you are so far south I doubt you have a need for ice melter.
    http://www.mortonsalt.com/for-your-b...lcium-chloride
    You can check the where to buy on that page, maybe a local hardware store can order you a bag from their warehouse? Ace hardware maybe? walmart ship to store?
    I got a bunch last spring on closeout
    I consider myself very lucky I found this site before the pool store found me-pool owner since Nov 2008- Stunningly clear 17,000 gal fiberglass pool, thanks to this site, installed in 1982-24" 3.1sq. ft sta-rite sand filter, 1 hp - 2 speed wisperflo pump-WFDS-4
    Jun 2014
    Houston, Texas
    475
    Yep, we've got the same problem. Rain, rain, rain. After we dumped 110lb of salt in, it poured and we had to drain water off! GRRRRR. AND I agree, that calcium stuff is expensive. it costs us $50 each time. Can we use calcium whatever from Lowe's????? anyone?
    19k SW IG
    Wet Edge pebble tech = new 5/16 (replaster)
    Hayward variable speed pump (new 6/17) /Shark for cleaning
    New - filled 10/18/14 - TFP 100 test kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    jojoman's Avatar
    Jun 2014
    Mandeville,La
    185
    CH has been dropping the last 2 months with all this rain. Started out at 375 when i first got the TF-100, now down to 325 this weekend. Tested the fill water and found that there is almost no calcium in our water. One drop and it changed color. So in the near future we'll be needing to add calcium to keep the pool balanced. Just one more thing to keep an eye on in having a balanced pool. CH up, Ph down and FC steady is going the be the summer program. Oh, and keep the trash that the wind and rain keep putting into the pool out
    12K gal, custom flipped kidney bean with spillover spa. All Pentair equipment, Whisperflo 1 1/2 HP, 400K BTU heater, Intellichlor IC 40 SWG, CCP-320 Cartridge filters, Kreepy Krauly pool cleaner with bootster pump, QuartzScapes in Aruba Sky blue, LED lights and travertine tiles for decking and stones on rear edge for landscaping. TF-100 test kit w/ SpeedStir
