Results 1 to 10 of 10
Thread: New pool owner
    May 2015
    Bethany OK
    3
    New pool owner
    I have a Intex 15x42 above ground pool 10,030 gallons. I am just now opening it for the year filling it up. Then have to treat it with all the chemicals and such haven't really done this to will be interesting. A friend told me he uses muratic acid to lower the Ph. Then bleach as a cleaner and baking soda for a stabilizer or to keep the algae down. I have no clue when it comes to this stuff.so any help is appreciated. Thanks
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,176
    Re: New pool owner
    Welcome to TFP!!
    How much Pool School have you read? Start with these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    Support the site
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,379
    Re: New pool owner
    What Tim said! ^^^^^^^^^^^^^^^^^^^^
    All of that and a good test kit like in my siggy you will be good to go!
    Kim
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: New pool owner
    Welcome to the forum!
    RyanMcC's Avatar
    Aug 2013
    NH
    214
    Re: New pool owner
    I'm a noob here so don't put a lot into what I say, but...
    1st: This place is incredible. I've been here almost 2 years but this is the first summer that I actually GOT IT and have gone with the TFPC method. My water has never, ever been clearer, I've spent much less on chemicals, and I more or less actually understand what I need and why. I'll be contributing for TFP Lifetime Membership in the coming month. Listen to what these people say- it may not always be what you want to hear, but it's extremely good advice and will result in great water.
    2nd: If I'm understanding you right, you have a 15' diameter, 42" deep Intex. I don't think there's any way that that could be 10,030 gallons. Last year we had a 20' x 48" Intex and it was less than 10K gallons. If you use the pool math page you can calculate your volume at the bottom. It looks like it's closer to 5,300 gallons. Make sure you know before figuring out your chemicals. If I misunderstood, just ignore me.
    "...chemistry is not an exact science" -Mario Andrada, Rio 2016 Olympics spokesman
    21' x 52" Radiant Metric Round ~10K gal AGP with Hayward S180t pump/sand filter.
    Caldera (Watkins) Martinique 340 gallon installed in basement, Bromine and ozone.
    Taylor K-2006 test kit.
    May 2015
    Bethany OK
    3
    Re: New pool owner
    You were correct I was reading a different chart for pump running time and I don't know where I came up with that. It is 3,284 gallons so I was way off.
    RyanMcC's Avatar
    Aug 2013
    NH
    214
    Re: New pool owner
    Good to know before you add chemicals! Once you have a good test kit, plug the results into the pool math page here and it will help you out with what to add. For the most part, it's all stuff from the grocery or hardware store. Bleach (make sure you get some that's not weak or that doesn't tell you the concentration- learned that the hard way), Borax, baking soda, muriatic acid, and a once per year stabilizer (from pool store) will likely do the trick. If you fill with well water, you might need a metal sequesterant at first (we always do). Check out the pool math page, seriously. Plug in your test results from a fas-dpd kit. It works!
    May 2014
    Franklin, NC
    9,176
    Re: New pool owner
    Quote Originally Posted by Newlon83 View Post
    You may want to check this article for Pool School out:
    Guide for Seasonal/Temporary Pools
    A smaller pool like that is normally "temporary" and can be treated a little different.
    Support the site
    May 2015
    Bethany OK
    3
    Re: New pool owner
    How do you test your CYA?
    May 2014
    Franklin, NC
    9,176
    Re: New pool owner
    With a pool test kit. Many folks would say have the pool store test it, but not much credence is given to pool store testing around here. While you would think that a "professional" would be the best, unfortunately in most cases it is quite the opposite. Between employees who blindly trust the word of chemical sales representatives and high school kids working in the pool store for the summer you end up with poor results from their testing. But, what can you do?? We base our pool care system on accurate testing and only adding what the pool needs, when it needs it. To do that you need your own accurate test kit. Order a TF100 test kit That will give you what you need for a couple of years normal use.
    The only other real option for a test kit is a Taylor K-2006. Be careful comparing prices because the K-2006 comes in sizes, designated by a letter. The basic K-2006 has .75oz bottles. Yo need to get the K-2006-C to get the larger bottles that you want. Even then it is a little short on the reagent & powder for the FAS/DPD test.
    I also have the SpeedStir and Sample Sizer. They speed testing and accuracy.
    Support the site
