Thread: Sump pump around pool
    May 2015
    london on
    3
    Hi all,
    I moved into a house over the winter and when I moved in I noticed that there was a sump pump around the pool. It has a black tube coming up and water filters out into the back corner of the yard.
    - Do you know the purpose of what a sump pump around the pool would be?
    - The piping above ground is rather unattractive, I was thinking about turning it off and taking the pipe down now that it is summer and reinstall before next winter.
    Your help is much appreciated!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,579
    Re: Sump pump around pool
    A picture would be very helpful. I am not sure of what you are talking about.
    Kim
    May 2015
    london on
    3
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,190
    I'm going to guess you have a high water table and they are trying to keep it dry around the pool. Do you have a vinyl liner?
    Support the site
    May 2015
    london on
    3
    Yes, it is a vinyl liner. When purchasing the house in late September it wasn't there. I'm assuming it was put up before the winter snow. Do you see any harm in taking it down?
    Jul 2012
    Tallahassee, FL
    30,579
    Is there any way you can get in contact with the former owners?
    If it is to drain due high water table you could float your pool and that is a bad thing
    Do any of your neighbors have pools? Maybe you can talk to them about what they do.
    Kim
