Thread: Mustard Algae Problem ??
    Apr 2015
    Simsbury, CT
    5
    Question Mustard Algae Problem ??
    Moved to new home last July. Pool already opened when moved in. No problems until late September until put solar cover on pool. After that, yellowish sand/dust would develop overnight at bottom of pool. I raised chlorine levels, and continued vacuuming, but not successful. Other than the yellowish sand/dust (which I am guessing is mustard algae) on the bottom of the pool, especially in areas where walls meet floor, the water was completely clear and looked clean.
    A pool company opened our pool this year (never again). Water cleared up a few days after opening. Since then I have been unable to keep chlorine in the pool (using combo of trichlor and liquid chlorine) and I have been seeing the yellowish sand/dust on the bottom of the pool again. (no luck with vacuuming, etc- just comes back next day).
    From my reading, I think I need to SLAM the pool. Just want to make sure that is the correct action before I try.
    Readings are at:
    PH - 7.2
    Clorine been running at under 1 (confirmed by pool store) except after adding large amounts of liquid chlorine (it was 4 today after gallon of 12%)
    TA - 100 (pool store analysis said 80)
    CYA - 50 (confirmed by pool store analysis)
    Am I correct that a SLAM is the only way to get rid of the yellowish sand/dust ?
    Should I do further testing before beginning the process ?
    Are these test levels acceptable to begin the SLAM process ?
    Also, I plan to fully clean the DE filter because it was not done last year and I do not know when the last time it was done, should I clean before or after slam?
    Could the solar cover have caused the algae (is there a way to clean?) ?
    Thank you in advance
    In-ground, vinyl, 18 x 36, Hayward DE filter EC65, Haywood pump
    2 skimmers, 3 returns (+ 2 bubblers by stairs)
    Owned pool 3 years, Tf-100 test kit, on well water
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,664
    Re: Mustard Algae Problem ??
    I see that you have a TF-100 test kit. Is that what you used to get your numbers?
    If those numbers are from your TF-100 they should be good to go.
    What does your pressure gauge show? I am not as familiar with DE filters. Please do a search to see what needs to be done. I am thinking it might be a good idea to clean it just because it has been so long but am not sure.
    Yes you do need to do a SLAM. There is even a part of the CYA/FC chart that gives levels for a mustard SLAM.
    Good luck and let us know how it goes!
    Kim
    30,432
    The first step would be to confirm you have algae. What happens when you brush the "sand/dust"?
    Can you pick any up off the pool floor between your thumb and finger?
    Apr 2015
    Simsbury, CT
    5
    Yes. My numbers are from a TF-100 test kit, so I assume they are good (although, I'm new to this, so they could be off)
    As far as the filter, the pressure is at 10 after bumping and adding new DE, but I can't say this was the "clean" pressure because I'm not sure of the last time the fingers were actually cleaned. (I think on this better to clean and "start fresh" so to speak")
    Also, yes, I can definitely pick it up in my hand, feels like sand / dirt.
    When I brush it just creates a brown dust ball. (that I assume resettles).
    The other thing that does not make sense in terms of it possibly being mustard algae is that there is nothing on the walls (and my pool does not have particularly shady areas).
    Could this just be dirt ?
    Would not opening the main drain have this affect ? (I am still trying to figure out the valves and the pool store opened the pool, but it does not appeal that the main drain is working)
    Thank you again.
    30,432
    Eureka! If you can pick it up and it feels like dirt/sand, it is not mustard algae.
    So it certainly seems like it is dirt (a pic would help) now to figure out where it is coming from.
    What is the psi on your filter gauge? Is it higher than normal? When did you last backwash/recharge?
    Do you have any reason to believe your filter is spitting this dirt back to the pool? Is their a lot of dirt in the atmosphere?
    Apr 2015
    Simsbury, CT
    5
    I cleaned and recharged the filter yesterday.
    Its running at normal psi.
    Did an overnight chlorine loss test last night and only down .5, from reading that means its not algae?
    (which also makes sense b/c able to pick up in hand and feels like dirt)
    Filter ran today, but didn't seem to get stuff off of floor ? (is it capable of that ?)
    Should the returns (3) (in addition to 2 by stairs that can't be adjusted) be pointing in specific direction to help with better circulation and kick up dirt from the floor?
    Will vacuum tomorrow and see if comes back.
    Should I put sock over return to make sure not spitting back after vacuum?
    (not incredibly dusty / sandy around)
    - can't get clear picture in the rain, will take when clears up
