Thread: Hey out there in Pool Land!! errr Water...
    May 2015
    Barrie/Ontario
    19
    Hello,
    Name is Brent from Ontario Canada. Built our pool over last year and finishing things this year. Its an in ground 36 x 28 foot L with the deep end being 36 x 18 and is about 8 foot 7 in deep. Just getting the majority of construction completed, pool is open and operational but need to save up to build the deck area.
    Running a Hayward salt system (T-15) and a Super Pump VS with a Swim Clear 425. We have 3 AquaLamps and I am currently assembling some Solar panels and applying some possible automation to the control system. There are corner stairs in the shallow end with a couple stair jets. 2 bottom suctions, skimmer and a side suction for the vacuum/cleaner.
    looking forward to learning!
    Brent H
    Inground 36000 gal, T-15 Salt system, 1.8 HP VS pump, 425 cartridge filter
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Hey out there in Pool Land!! errr Water...
    Hi Brent,
    welcome to TFP.
    To start the learning process, click on that big Pool School button at the top of the page and start with the ABC's of pool chemistry.
    Pool School is an invaluable resource and the ABCs is the best place to start in learning how to take care of your pool.
    Divin Dave,
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to the forum!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Welcome to TFP! Congrats on the new pool!
