Results 1 to 9 of 9
Thread: Winter pool tile cleaning methods
    iggy's Avatar
    Jan 2008
    The Cool Part of Arizona
    175
    Hi All.
    It is now winter in the desert and I have lowered the water level below my tiles.
    I would like to do some preventive maintenance and clean the tiles which have built up some calcuim/lime staining between the tiles in the grout as well as some on the tiles.
    My plan is to do a acid/water wash with the green scrubby pads and make the mixture strong enough to bubble it away. I don't think that any sprayer bottle would work as it would distroy the pump. Any suggestion on your methods you have used to cleean the tiles and grout lines?
    Iggy in the cool part of Arizona 8)
    In-Ground SWG pool 11,000 gal., Jandy CL460 Filter, 1.5hp Stealth Jandy pump, Paramount PV3 In-Floor cleaning sys., Goldline SWG, Hayward Color Logic 2.5 LED Light
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    Re: Winter pool tile cleaning methods
    I've tried allot of different cleaners to remove hard water deposits that have accumulated on my tiles, the best thing I found was a pumice stone and some elbow grease.
    I also live in Arizona but I've never found the cool part, just where is that???
    My pool is a 10,500 gallon (420 Sq Ft ) kidney shape. STA-RITE HRPB30, Sand filter 30" 98 GPM, 1 HP Maxi-Glas 2 pump, BBB Method, Taylor K-2005 test kit, 50 Watt 12V low-voltage pond light illuminates the pool at night for a nice soft glow.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    I have sprayed diluted muriatic acid to clean brick, and the spray bottle held up fine. Acids don't eat plastic or you couldn't store them in plastic jugs.
    Sep 2008
    The Woodlands, Texas, USA
    243
    When we bought the house, the tile had a lot of buildup. It was expensive but I hired a franchise called Tile Savers to sandblast the tile clean. Worked great. Took them 4 hours and $800!
    IG 24k plaster with overflow spa. Goldline PS-8 SWG. Tristar 0.75 HP filter pump, Polaris 280, large cartridge filter, 400k BTU NG Max-E-Therm HD, SR Smith Turbo Twister, Life Saver pool fence, ORP managed.
    30,426
    JohnT is, of course, correct about acid not reacting with plastic. If I'm not mistaken, I think you will find the 3M scrub pads will be eaten. I seem to remember using them in an acid wash application and they didn't hold up well.
    Most "deck" brushes are acid-resistant (not the nylon ones but the natural bristle ones) and will give you enough abrasive action to compliment the chemical reaction of the acid.
    The only way to clean the white bath tub ring is to have it done
    professionally. They will use glass beads to blast off the calcium, this is the only
    process that really works.
    If you don't want the white ring then you will have to reduce the calcium in the
    water. There is a company in Phoenix(might be elsewhere) called Calsaway.
    They have a process that removes the calcium from your pool water and will keep the
    white ring form coming back.
    I tried some rather expensive products that did nothing. Don't bite on the pool store
    trying to sell you any of these products, they just don't work.
    Cliff s
    budster's Avatar
    Dec 2008
    Savannah Historic District
    272
    Two products have good success on Hilton Head Island (the service companies there). One is the Bio Dex 300, and the other is the Poolboy product which mixes with Muriatic acid. The latter is referenced somewhere else on this forum. Good luck.
    http://www.swimmingpool.com/
    "Leave the gun...take the cannolis"
    30,426
    Muriatic acid will eliminate calcium deposits when used in the correct strength.
    "Correct strength" is the caveat......incorrect strength can also eliminate your fingers!!
    pedroheredia672's Avatar
    Jun 2013
    Morrisville, NC 27560, United States
    1
    Very useful to us newbies, thanks.
