Results 1 to 12 of 12
Thread: Beach entry pool-silver quartzite tiles with water seepage problem
    Jan 2013
    Southern CA
    50
    Hi- I'm back Moved (left lagoon style pool behind) and just finished building 40k+gal beach entry pool. We used the quartzite tiles to blend in the beach entry and raised bond beam area. Didn't realize there would be a seepage problem with the grout until pool filled. I don't like the way it looks and complained to PB. He said we can wait till after swim season and we can drain it down some to seal the grout then. Does this sound like a good idea, and would it effect the pebbletec being dried out for few days? Thank you for any input! Here's couple of pix of the problem.
    May 2015 completed- 50'x30' beach entry(26'), two 50' swim lanes, diving board, jump rock, 4'-9.5' depth, 40K+gal salt water, Pentair,Screen logic 2 mobile for intellitouch., intellichlor and intellichem automated system. Jacuzzi JLX cuz we rarely used the last in ground spa :)
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Beach entry pool-silver quartzite tiles with water seepage problem
    I think if it's cool you should be fine. Prolonged exposure in the hot sun wouldn't be so good on it.
    Essential Links:
    30,431
    does your pic show the seepage? Do you mean where water has migrated up the stone?
    Jun 2011
    Carlsbad, NM
    172
    Sealing the grout won't work for long.
    36' x 18' 20k in ground, Finest Finish grey plaster, Pentair Tagelus 100D sand filter, Hayward Northstar 2hp pump, Jandy LRZ125EN heater, spill over spa, iaqualink controlled automation, Stenner chlorination, natural rock and flagstone coping, 1" glass mosaic waterline tile, SR Smith Vortex slide.
    Jan 2013
    Southern CA
    50
    Yes Dave- I mean the water creeping up the wet grout. I guess it's all cosmetic, just doesn't look good to me though.
    Smracing- you mean sealing doesn't work? Any other options?
    Thx,
    Mary
    30,431
    I doubt sealing the grout will work at all. The water will migrate up and underneath any sealer you put on it. It might help but I would not be surprised if it does nothing. Unfortunately, I can think of no way to prevent it.
    Jun 2011
    Carlsbad, NM
    172
    I'll explain what I meant. I have pewter colored grout that matches my plaster. I sealed it with an enhancer that made it darker, better matching the wet plaster. Not a cheap sealer either, Dupont's Stonetech Pro solvent based. It lasts about 3 months, the the grout eventually returns to the unsealed color.
    Jan 2013
    Southern CA
    50
    Oh! I guess I should wait until after swim season and ask PB again. Wish they used a white grout instead of the gray then it wouldn't have been noticeable. My landscaper used white on the stone on the driveway and it looks the same when wet, not darken like the gray. Oh hey, new question- how complicated would it be to change out the top layer of grout?
    Jan 2013
    Southern CA
    50
    So is it possible/feasible to just replace the top layer of the gray grout and put on white grout which looks fine when wet? And do you seal the quartzite?
    Jan 2013
    Southern CA
    50
    Someone posted on sealing their stone with Dry Treat - would that work on the grout? And does that darken the stone with the wet look- like the pieces in the water? I don't want to darken the "dry" portion of the beach entry that extends into the deck so best not to seal?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Looking this over again, I don't think it would bother me at all, especially on the beach entry. I kind of like it there. The walls, maybe I can see that a little, but it wouldn't ruin my enjoyment I don't think.
    Essential Links:
    Jan 2013
    Southern CA
    50
    Well Patrick, I was letting your comment sink in- maybe i'll just get used to it and enjoy. Then today the pool maintenance guy (not ready for hubby to take over) shows up using powder acid to clean the lime or whatever on the beach entry. And he says- didn't they seal this? WAAH
