Page 1 of 3 123 LastLast
Results 1 to 20 of 44
Thread: chem geek
    30,426
    chem geek
    In the wee hours this AM, chem geek made his 10,000th post.
    That's a milestone for a couple of reasons.
    1. 10,000 posts is a ton of effort over a long time and indicates a dedicated, contributing member
    2. It's an even bigger milestone because of chem geeks very special knowledge he brings to the forum.
    chem geek and I knock heads every now and then but I will tell you I have never met a more sincere person or a person that has contributed more to the technical aspects of what we teach.
    The FC/CYA chart is a chem geek credit. He didn't just copy the chart but rather did the math and calculations to make the chart possible.
    Each time we need a detailed explanation of chemistry, he is on the spot with precision and acumen that is untouched. Much of what we teach is a direct result of his (and JasonLion's) contributions.
    I hope the rest of you will chime in and stop to remember how important his contributions to this forum are. I am going to keep my thoughts brief but I hope this thread is ongoing for the rest of the day......maybe into tomorrow.
    Thanks, Richard!
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    Re: chem geek
    Congratulations to chem geek. I have learned so much from him. Thank you.
    27,500 gallon in ground gunite/plaster (1995). Attached Spa with fountain, spillway, and 2 lion heads streaming into the pool. Hayward pump and AO Smith UST1152 1.5 hp motor (single speed). Hayward 60 sq ft DE Filter (Model DE-6000). Kreepy Krauly cleaner.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,034
    Re: chem geek
    That IS a huge accomplishment, because his posts are generally lengthy. One of his is easily worth twenty of mine.
    You all do know that he was the model for this, right?
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: chem geek
    Ok, since it's been mentioned, I have a confession to make. chem geek is my hero!
    There are only a handful of people in the world that I have the same respect for, as I do Richard. The guy rocks and that's all there is to it!
    If it weren't for his scientific analysis and attention to detail, I probably would not have become a mainstay here at TFP.
    I love science and whether I understand it or not, I firmly believe in it, and if you can't prove it to me, then its just water off another ducks back.
    Richard proved it, and for that, I and I'm sure 1000s of others are grateful.
    10,000 posts, and with the detail he involves, I would imagine on average 15 minutes per post (conservatively) to type and link, and calculate and post.
    Thats conservatively 150,000 minutes, 2,500 hours, 104.16 24 hour days... it's mind boggling the time and knowledge he has given us.
    Richard,... Thank You!
    Divin Dave,
    May 2015
    Chicago, IL
    508
    Re: chem geek
    Congratulations on the accomplishment chem geek.
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    Re: chem geek
    I am in awe every time I read one of chem geek's posts. Even when they are way over my head! His knowledge is impressive to say the least.
    Thank you chem geek for everything!
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
    May 2013
    Long Island NY
    419
    Re: chem geek
    The Gin clear water in my pool is the result of his dedication and effort, I thank you Sir. Thank you for your time and knowledge.
    19,000 gal - Vinyl IG - Sand filter -1.5hp. - Taylor k 2006 - Loop Loc cover
    Jul 2014
    Peoria, IL
    389
    Re: chem geek
    Congrats on the milestone ChemGeek!!!
    And thank you for your contributions. Your posts were some of the first that I saw when I came on here with a hazy pool and I remember many of your posts verbatim
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    JoyfulNoise's Avatar
    May 2015
    13,227
    Re: chem geek
    I lurked on TFP and the PoolForum for years. ChemGeek's work should be required reading for anyone interested in pool water chemistry and his cool and crisp writing style brings a level of scientific rigor typically only found in the best scientific journals. His willingness to field questions and correct rookie mistakes in chemistry is a testament to his sincerity and dedication.
    Congratulations and THANK YOU!!
    Matt
    38,345
    Re: chem geek
    Congratulations, that is quite an accomplishment.
    While admittedly many of your posts fly right over my head, the chemistry details you bring are what gives this method legs to stand on. And for that we THANK YOU!!!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,559
    Re: chem geek
    He is one of the best out there. He knows what he is talking about AND is able to share it in such a way that anyone can understand it!
    THANKS!
    Kim
    Re: chem geek
    Thanks for everything you do, chemgeek. Your contributions are very valuable and appreciated.
    Support the site
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: chem geek
    Wow. Thanks everyone. I had no idea I had just passed that 10,000 post milestone. I appreciate all of your sentiments/comments. I learn a lot as well and I also make the occasional mistake and though I often discover and recover before someone catches it, I appreciate when James and others find it or add additional info (preferably from scientific papers in respected peer-reviewed journals, of course ). There are so many people that contribute to this forum in so many different ways, but there are others such as Jason and Mark and onBalance and ... (many others so no offense if not listed) who have spent a lot of time building up a vast database of knowledge and facts here on this forum.
    Chemistry is my main focus, but there is so much more needed in building and maintaining a pool including electrical, pumps, and plaster, let alone comparing brands. No one person could possibly be an expert in all such areas so this is very much a team effort. And this is just the scientific foundation -- the vast majority of pool owners don't care about that nor want to know about it so there are many people here who translate the core into easy-to-understand and easy-to-implement guidelines that are both practical and useful.
    And Dave is to be credited for keeping this place civil. So many forums and other online groups devolve into shouting matches or inappropriate content. Keeping this place friendly is a big part of its success.
    So again, thank you.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: chem geek
    chem geek: You, sir, are a steely-eyed scientist!
    10,000 posts...there's currently only 8 members in that elite club. What I find just as remarkable as his in-depth knowledge on all things chemistry-related is his zen-like demeanor. He will stay with a user who is really trying to resolve a problem but, for whatever reason, seems to be stuck in neutral. In addition, he will educate someone who is making false statements and do it in such a way that does not come off as condescending. Of course, we all enjoy the occasional post where he puts a particularly recalcitrant member in their place.
    Of all the articles/links I have referenced in my posts, I'm willing to bet that the Chlorine CYA Chart is probably the one I've referenced the most. Pool owners that understand this one concept will avoid a majority of problems that plague those who don't.
    Quote Originally Posted by Divin Dave
    I'll second that!
    Thank you Richard for all your contributions to the world of pool management. Look forward to continuing to see you on the forum!
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: chem geek
    Mark
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    Re: chem geek
    Meh....he's alright.
    Congrats!
    27' AG 18K Gallons ~ Cartridge Filter ~ Pentair 1.5 HP Pump
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: chem geek
    Congrats, Chem Geek!
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    Re: chem geek
    Thanks for everything Chem Geek. You have helped me more than once. That is a lot of typing you have been doing!
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,077
    Re: chem geek
    I appreciate Chem Geek for putting the smack down on people who argue with TFP philosophy. "Oh yeah?? Check this out" :firehoseofscience:
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
  20. Back To Top    #20
    May 2014
    Owen Sound, ON
    44
    Re: chem geek
    Thanks Chem Geek! You are a righteous dude! LOL!
    Intex 24'x12'x52" Ultra Frame (2014), 8400 gallons (31800 litres), Intex sand filter and pump, AquaBot Pura4xi, solar blanket, 32' x 10' deck across one side, 4' decks up short sides, better ladder. Proud owner of Hydropool Serenity 5 Hot Tub! Taylor K-2006 Test Kit.
