Results 1 to 10 of 10
Thread: Feeling in control. Love the test kit
    May 2015
    Cherry Hill NJ
    11
    Ph 7.4
    cya 40
    TA 120
    TC 7.5
    CC 2
    FC 5.5
    27 ft above ground with sand filter.
    Hayward Power Flo LX
    17,000
    TF-100
    38,475
    Re: Feeling in control. Love the test kit
    Your CC appears to be too high ... ideally should be 0. Might point to needing to follow SLAM process.
    30,431
    Yeah, that CC number is a little too high. What does your water look like?
    Jun 2014
    15,221
    I agree with Jblizzle on the CC. The good thing is now you can actually get those accurate readings all on your own. Congratulations on the TF-100!
    May 2015
    Cherry Hill NJ
    11
    Ok here we go. Was sloppy on technique. Put too much powder in.
    Redid the test.
    CC. 0
    FC 5
    pool water is crystal clear.
    17,000
    TF-100
    38,475
    You can not put too much powder in.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,011
    Congrats on the test kit.
    here is a good tip for you.
    After you do the FC test, do not let the solution sit before doing the CC test. The water can go back pink again if you let it sit which will give you a false high CC result. Use teh R0003 and do the CC test immediately after doing the FC.
    Divin Dave,
    May 2015
    Cherry Hill NJ
    11
    That had to be the problem. I did the first test pretty slow. The second time I didn't have to read.
    thanks again.
    17,000
    TF-100
    30,431
    So, now back to your original post....Congrats!! You have a great grasp of the principles involved and are on your way to a troublefree swim season. Nice work!
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Great work SJSF08002
    Liberating to be in control of you pool, isn't it!
