Results 1 to 11 of 11
Thread: Need a recommendation on a pool timer.
    caliskier's Avatar
    Aug 2014
    Oklahoma City, OK
    231
    All, I need a recommendation on a pool timer, mine does not have one, given the cost to run these things I am quite surprised. I have researched amazon and see the same pool timer that my dad had in the 80's. That's not to say it's bad, great reviews. But just wanted to know if anyone would do something different, newer given the opportunity.
    The setup I have is a pool and hot-tub combo. I might someday want to run the pump and filter for just the hot tub in the winter and so a switching feature for freeze protection would be a nice to have. My current setup has just that, a temp protector, no timer, and a 3 way flip swich: On, Off, and a middle which I assume is off until the temp protection is kicked on.
    If I already have the temp sensor, I wonder if there is a way to wire it in Boolean logic such that if the timer OR the sensor trips, the pump turns on.
    This is my current setup, any recommendations?
    This is what I am considering, but has no temp setting.
    Amazon.com : INTERMATIC INC T104P3 TIMER INDOOR/OUTDOOR 220V PLAS : Watering Timers : Patio, Lawn Garden
    or
    Intermatic T104 208-277-Volt DPST 24 Hour Mechanical Time Switch - Intermatic Timer - Amazon.com
    Owner since August 2014. 21,500G Liner In ground Pool with attached 600G plaster in ground hottub. TF-100 Test Kit, Filter: Pentair TA60D Clearpro Sand (HTH) Filter. Pool: 1 Drain, 2 Skimmers 4 Returns. Hot Tub: 1 drain, 1 skimmer, 2 returns. Hot Tub/Pool run by Sta-Rite Dura Glas Single Speed 1.5hp P2RA5F-182L pump with Emerson K63CXESE4972 motor. Spa jets run by Sta-Rite Dura Glas H/L model number unknown.
    caliskier's Avatar
    Aug 2014
    Oklahoma City, OK
    231
    Re: Need a recommendation on a pool timer.
    Pretty please?
    DaneCE's Avatar
    Jul 2011
    VA
    279
    I bought an inexpensive timer last June made by Woods. It's been great so far.
    Amazon.com: Woods 50015 Outdoor 7-Day Heavy Duty Digital Outlet Timer: Home Improvement
    ps0303's Avatar
    Jul 2011
    FL
    3,699
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    +1 on theET1105C. Its a digital timer and has a ton of functions and has built in freeze protection.
    You can connect both your spa and pool to it and can run a ton of schedules if you want to.
    By the way, the T104 you linked to is not rated for outdoor. The outdoor model is the T104R.
    Quote Originally Posted by ps0303 View Post
    Divin Dave,
    I don't think the et1105 has freeze protection.... I was going to recommend the et1125 but it doesn't have freeze protection either..l
    caliskier's Avatar
    Aug 2014
    Oklahoma City, OK
    231
    Quote Originally Posted by Divin Dave View Post
    Thanks, the ability to run the spa is nice. I was going to eventually look for a timer for that. My hot tub runs on the same pump as the pool for filtering, but has a separate pump for the jets. I assume I am 220, but how can I be sure?
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Look on the name plate of the motor, if its still there. It will list the operating voltage.
    If the tag is gone, then find out where the power cable for the pump connects to a breaker. If a 2 pole breaker is providing power, then its 220V. If its a 1 pol breaker, its 120.
    Quote Originally Posted by caliskier View Post
    Divin Dave,
    caliskier's Avatar
    Aug 2014
    Oklahoma City, OK
    231
    According to Stebs, it does not have freeze protection?
    caliskier's Avatar
    Aug 2014
    Oklahoma City, OK
    231
    Ok, I have been flipping the switch for the last few months, this was not a major priority but it has become one. It is powered by a 220 breaker.
    So help me understand, looking at my picture in the first post, I have that 3 position wall switch, down is off, middle is off (I assume freeze protector thingy above on) and top is on. Because I can flip this to all the way off, I really don't want to use the mechanical timer as I will have to reset the time each time I accidentally cut the power completely or just need to shut it off right?
    So if I hook up the electrical timer which has batteries, and accidentally switch it to the down(off) position, I assume it will still keep the time and I don't need to reset it. Right? and likewise in the all the way on position, if this cuts power to the timer, I assume it will still keep the time.
    I guess what I am asking, with this setup, for those reasons above, I have to get the electrical timer, yes?
    caliskier's Avatar
    Aug 2014
    Oklahoma City, OK
    231
    This is probably more of an electrical question vs. a pool question, great money saving suggestion on the timer, I should probably take this swiching issue over to my electrical forum.
    Thanks guys, saving money day after day...
