Results 1 to 9 of 9
Thread: Tf-100 calcium hardness test
    May 2015
    Union, NJ
    128
    Quick question, I watched a youtube video showing how to perform the calcium hardness test, which ask to fill the water to the 25 ML mark not the 10 ML mark as the directions on the TF-100 kit. Also it ask for 20 drops of R-0010 instead of 10 drops and 5 drops of R-0011L instead of 3 drops. Why? I understand that is a matter of ratios, but the ratio seems to be off, as if 10 ML requires 3 drops, 25 ML shall require more than 5 drops as 25 ML is more than double 10 ML so it shall be the drops required to perform the test correctly. I know I shall trust the TF-100 kit directions over a youtube video, but just wanted to confirm just in case.
    20,000 Gallons, 33.9 x 19.9 free form inground plaster pool 7 feet deep with Spillover Spa, Salt Generator (Fusion Soft),Heat Pump, Single Speed 2 HP Pump, D.E. Filter. Zodicac PDA, IQ900RS Controller.
    38,242
    Re: Tf-100 calcium hardness test
    Either way is fine. There is no need to have more precision that 25ppm in most cases, thus the TF-100 recommendation.
    The ratios of the reagents does not really matter. You can actually use as much of the die reagent you want to have deeper colors.
    May 2015
    Union, NJ
    128
    Jason thanks for the quick response!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    If you have astronomical CH, as I do, the smaller sample saves a huge amount of reagent and time. If I used the large sample and had to swirl it manually instead of using the speedstir, I'd look like Popeye now.
    May 2015
    Union, NJ
    128
    I see. One more questions when looking at the tube. Do I look at the color change from the top and through the side? I notice the colors look difference based on the angle you looking at.
    Richard320's Avatar
    Jan 2010
    18,967
    Quote Originally Posted by RESISTENCIA13 View Post
    I've only ever looked through the side while it's sitting on the patio table on the speedstir in front of me. It'll be sky blue. About this color
    38,242
    It does not matter what the final color is. Always add drops until the last one causes no further color change and then do not count that drop.
    Richard320's Avatar
    Jan 2010
    18,967
    That's true. I know from experience that when CH is astronomical, it will sit at Indigo for quite a while before it goes blue. That's why I mentioned sky blue.
    May 2015
    Union, NJ
    128
    Thanks
    Thanks
