Results 1 to 12 of 12
Thread: Anyone know what this is?
    Lizbethmcq's Avatar
    May 2014
    Parkesburg PA
    46
    When the pool guys left on Thursday (no activity on Friday) this item was left in the bottom of the pool. It's plugged into the electrical outlet and has a garden hose attached but it's not attached to a water source.
    Liz
    17,500 gal, IG Trilogy fiberglass sport pool 43'8"x16', Jandy Cart CS Ser filter, Jandy Pro Ser+ 1.5 HP pump, Nature 2 Fusion Soft SWG (mineral removed), TF-100 test kit w/ SpeedStir, Dolphin Oasis Z5 robotic cleaner. Maax Spa 481 (455 gal)
    Tulsa, OK
    4
    Re: Anyone know what this is?
    it's a small electric pump.
    Apr 2015
    Ontario
    10
    Sump Pump. To pump the water out of your pool?
    Lizbethmcq's Avatar
    May 2014
    Parkesburg PA
    46
    Can't be, they just filled it on Thursday its a new build...
    Liz
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Is the main pool pump up and running? If not, they may have temporarily placed this portable pump just get the water circulating.
    It's a Little Giant submersible cover pump. Why it's there is not obvious. Perhaps to remove some water or to create circulation if the pool pump is not working.
    Support the site
    Corleone's Avatar
    Aug 2014
    Menifee/CA
    194
    Quote Originally Posted by Lizbethmcq View Post
    It's definitely a sump pump.
    13K Gallon IG Pool/Spa -- First time pool owners -- Completed in 2015 Caribbean Blue Pebble Tec Pentair 4000 Series 47 sq. ft. D.E. Filter Pentair IntelliFlo Variable Speed Pump Pentair SWG Jandy LXi Heater 400,000 BTU S.R. Smith Typhoon Slide Pentair LED 12v Lights Dolphin Nautilus Robotic Cleaner TF-100 Test Kit
    Our Build Thread
    Lizbethmcq's Avatar
    May 2014
    Parkesburg PA
    46
    Ok that makes more sense, we are waiting for the electrician to hook everything up so no pumps working at this time. I don't see that it's doing anything, no water moving that I can see.
    Liz
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,193
    Where is the other end of the hose?
    Support the site
    Lizbethmcq's Avatar
    May 2014
    Parkesburg PA
    46
    It's in the pool, not connected to anything
    Liz
    May 2014
    Franklin, NC
    9,193
    Did you pull it out and see if water is comoing out of it. As you say the electric is not hooked up yet they could be using that pump to help circulate water. It's a small pump, so low volume and it may not appear to be moving water.
    Support the site
    Lizbethmcq's Avatar
    May 2014
    Parkesburg PA
    46
    Yep just picked up the hose and water was flowing - thanks everyone. It was driving me nuts not knowing what it was.
    Liz
