Thread: Pump on or off when adding chemicals to water?
    appstategrad's Avatar
    Jul 2014
    Hickory, NC
    154
    This is a straight up newbie question...
    I read online (on several different websites) that the pump should be off when adding baking soda to raise TA. Guess I've been doing that wrong! I always turn my SWG off before adding anything, but I was surprised to read about the pump and baking soda. Is there a list of what needs to be added with the pump off and how long to leave it off? Conversely, what needs to be added with the pump on and how long to run after adding? Thanks!
    Sent using Tapatalk
    ~ 18.5' x 36.5' inground Grecian pool with vinyl liner
    ~ approximately 23,000 gallons
    ~ AquaRite Salt Water Generator cell size t-9
    ~ 1.5 HP Hayward Pump and Hayward Sand Filter
    ~ TF-100 test kit
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Pump on or off when adding chemicals to water?
    You should always have your pump running when adding anything so it can get circulated properly.
    You shoul run it for at least an hour before turning it off after adding.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Jul 2014
    Hickory, NC
    154
    That is what I thought as well, which is why I had left it on...especially since I don't add anything through the skimmer except CYA in a sock. I only questioned it because I had seen it in multiple places. Thanks!
    Sent using Tapatalk
    ~ TF-100 test kit
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Your welcome. Always better to double check when you are not certain.
    Lisa
