Results 1 to 9 of 9
Thread: 1st post and 1st TF-100 check
    May 2015
    cochran\georgia
    22
    FC 12.5
    CC 0
    pH 7.5
    TA 110
    CH 225ppm
    CYA 110
    Water clear since initial 4 day clear up after opening 5 weeks ago. I'm going to drain some water off to get my CYA down so I can quit using so much chlorine. Suggestions welcome!
    33,000 gallon, IG vinyl, Nautilus FNS PacFab DE filter (7, 12 in grids and 1 partial), 1HP Hayward Super Pump Mod#SP2607X10, 3\4HP Polaris PB4-60 Booster Pump, Well Water, TF-100 Test Kit
    30,414
    Re: 1st post and 1st TF-100 check
    Welcome to the forum.
    I see nothing to change in your pool chemistry or plan to reduce CYA. If you chlorinate with an SWG, take CYA down to around 70. If you chlorinate any other way, take CYA down to 50 ppm.
    You have a good grasp of all the concepts. With your already clear water, you'll have a Troublefree summer!
    May 2015
    cochran\georgia
    22
    THANKS! I'll be shooting for 50.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    That looks good!
    May 2015
    cochran\georgia
    22
    Any suggestions on how far to drain this 12 year old faded out liner. I'm hearing a foot below the skimmer to a foot in the shallow end. I started yesterday pulling from the main drain with 2 hoses filling at the same time thinking I wouldn't be pulling the fresh water. I've been told a foot below the skimmer to a foot deep in the shallow end. Also been told to watch the liner at the corners at the top and bottom to make sure it's not pulling away from the wall or lifting from the bottom.
    DFW, TX
    24,483
    Yes, those are the guidelines. Maybe err on the side of caution with the older liner and go a foot or 18" below the skimmers.
    May 2015
    cochran\georgia
    22
    Thanks! Seems I've read that it can take a week to get an accurate CYA reading after draining and refilling. Is that correct?
    DFW, TX
    24,483
    Close. It takes a week for newly added CYA to fully dissolve and show up on the test. For a drain and refill just run the pump for 30min after it is full to mix the new and old water and test.
    May 2015
    cochran\georgia
    22
    Thanks again!
