Thread: Gas / Water Lines
    Riles_J's Avatar
    Nashville, TN
    218
    Gas / Water Lines
    I am in the planning stages of my outdoor kitchen that will be constructed on a new deck that sits up off the ground about 3'. I would like to run my gas and water lines to my outdoor kitchen above grade connected to the bottom of the joists in some fashion. Are there any issues with running gas in this manner? Trenching them into the ground will be difficult to do. I plan to slope the water lines to enable me to drain them in the winter, but I can do without the sink for the winter months.
    Any thoughts?
    Riles
    16x32 IG vinyl, 19,000 gal, 1.0 hp pump, sand filter, 2 returns, 1 skimmer, diving board, slide
    DrDave's Avatar
    May 2008
    Fallbrook, Ca
    154
    Re: Gas / Water Lines
    If you are concerned about codes then you need to consult your local authorities. For me, I just do it as safe as I think it needs to be and that generally is overkill with no fees or inspectors to make your life miserable.
    DrDave
    http://plansbyjorde.tripod.com
    Necessity is the Mother of Invention
    If you have a basement, like me, you could go down there and see this is how they run the black pipe to a kitchen island, so you shouldn't have any problems.
    I actually put a 3" pipe under my patio to run the gas line through, and paid my propane service tech like $75 to come hook it up (I had it pre plumbed.)
    NOTE about gas lines...make sure you put in a shut off valve that's easily accessible, and get in the habit of turning it off EACH TIME you use the grill. My buddy didn't have this and forgot one of his burners left lit. It burned through $2500 worth of NG before he found it. I'd only get to 800 gallons of propane, so $1600 max, but still, I'm paranoid about it now.
    Richard
    Temecula, CA
    28,000 Gal. In-Ground plaster and tile, Total Control AutoPilot with SC-60 SWG and PH control, Pentair EasyTouch 8, EasyTouch Wireless Remote, Intelliflo VS+SVRS pump, Intellibrite lighting, Pentair Quad 100, Solar heating, Pentair Mastertemp 400 Gas Heater, The Pool Cleaner 4x, Aquabot Turbo T2 Robotic Cleaner, Water feature spillover from SPA.
    22,539
    You do need to check with your local athorities but the general rule of thumb is that if the space is not readily accessible it's ok to run the gas line hung from the joists. (I.E. crawl space under a dwelling.)
    As stated, there needs to be a readily accessible shutoff where the line exits the ground. And that needs to be clearly marked.
