Thread: Heater on and white water out
    May 2015
    williamstown
    3
    i turned the heater on and kids are in pool this is the first time of the year. white water is coming from the returns. am i poisoning the kids. help?
    PoolESQ's Avatar
    Dec 2007
    Albuquerque, NM
    191
    Re: Heater on and white water out
    You sure it's not small air bubbles mixed in with the water?
    Replastered 2015: Sunstone Quartz Midnight Blue 16x32 rectangular gunite with in-pool spa....18,000 gallons. Autopilot Total Control System with SWG and acid pump. Pentair Clean & Clear 420. Auto cover. TF-100.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Welcome to TFP!
    How about some test results? And is it one of these test kits, Pool School - Test Kits Compared?
    Here is more info needed for us to be able to help you, Pool School - Read This BEFORE You Post
    Jun 2012
    western NY
    1,560
    Based on a comment you made in another thread about dumping some magic elixir into your pool we have no idea as to what is causing that. As Poolesq said, could be bubbles in the water. It also could be a reaction to the heat from the unknown stuff you dumped in. As to poisoning the kids...hard to know, I doubt it, but again we don't know what you are using in your water. Please go to the Pool School tab and start reading there to have a better understanding of what is going on in your pool. Also, you will notice that almost all posters here have a signature line at the bottom of their posts that have at least a basic amount of info on their pools. This helps us immensely when trying to diagnose certain problems
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    wjr75's Avatar
    Jun 2013
    IL
    836
    Colud be calcium build up in your heat exchanger.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
