Thread: need new pump for solar heating
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    488
    hi , currently have a davey xa105 3/4 hp pump for my solar
    it doesn't appear to be a self priming type and if i don't keep an eye on it it loses prime
    anyway must have lost prime for around a week and been running 8 hours a day
    i think it is now dead as it seems deformed and isnt running anymore, just a buzzing noise
    could be the run capacitor but i dont like the look of the pump housing, and have been looking for an excuse to get rid of it
    looking at davey typhoon t150 as it is self priming
    t150 is 1.5hp and 2inch pipe outlet, my current outlet is only 1inch, so will need to step it down
    can the pump be too big, need about 20ft head hight for the solar
    thanks for any advice
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: need new pump for solar heating
    Is this pump only for solar? Normally, solar does not require a separate pump. I used a 1/2 HP pump for my solar and filtering on top of a two story house.
    Mark
    aussieta's Avatar
    Jan 2014
    488
    it is an unusual setup
    the solar is a completely seperate pump with its own inlet and outlet to the pool
    local pool shop said the pump we have xa105 is meant to be plumbed into the main filter line just after the main pump
    not used as a stand alone system as it isnt self priming
    pool shop recomended the silent model sls150 as it has cheaper running costs
    also mentioned that my pipe size should have been stepped from 1inch to 1 5/8 inch immediately after pump
    mas985's Avatar
    Pleasanton, CA
    11,737
    It looks like the sls150 should work ok for a solar application.
    Mark
