Thread: Pump upgrade
    Cool Pump upgrade
    Hello everyone. Pool is up and running and working well thanks to the advise of this site. I am thinking about upgrading to a 2 speed pump. Thinking about the Hayward power flow matrix 1 hp 2 speed. I have been told that my pump s way oversized for my filter. Would that pump be a better match for me? Any thoughts? Thanks in advance
    14000 gal AG vinyl liner. 150lb Hayward sand filter 1hp 2 speed pump.
    38,516
    Re: Pump upgrade
    Hard to say since you do not provide any details about what pump you currently have.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Re: Pump upgrade
    This pump has become my new favorite pump.
    Pentair SuperFlo VS Pump 342001 | Pentair 342001
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,058
    Re: Pump upgrade
    I have a 1 hp on my 16000 gallon pool and it's plenty. So a 1 hp on your pool should be fine. Your current pump probably is a bit oversized. Just look for the motor with the same mounting flange and you won't have to touch the plumbing at all.
