Thread: Using a pool cover
    May 2015
    Fullerton/CA
    1
    Using a pool cover
    I just put a pool cover on my pool. Should I be able to reduce how often my service guy comes to clean, say from once a week to once every other week?
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    Re: Using a pool cover
    Welcome to TFP.
    While a cover may reduce the amount of debris that gets into the pool, I'm going to hazard a guess that your pool service is also managing your water chemistry, in which case the answer is no.
    If you're interested in reducing or eliminating the service, purchasing one of the recommended test kits (TFT100 or Taylor 2006, here's a link : TFTestkits.net) and reading through Pool School would arm you with the knowledge to maintain your own water chemistry in a very easy and quick way daily.
    Then you could choose how frequently you have a service come in terms of the "physical" labor such as vacuuming. OT for that atter, purchase a robot cleaner instead.
    Let us know if we can assist.
    Also note that while covers can reduce debris, conserve heat, and to some extent reduce chemical useage, pool water does benefit from sunlight and open air to reduce combined chloramines, ccs or spent chlorine by products that need to be broken down. So you would not want to leave the cover on all the time.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Good water needs to breath and circulate. What about getting an automatic cleaner. The modern robots are great, and even old school Polaris's will keep it clean on a timer.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
