Thread: TF-100..."Chlorine Only" Tube
    May 2015
    Lexington, KY
    73
    During the Chlorine Test, it says to use the "Chlorine Only" tube. Any particular reason that this is labelled so specific? I bought the magnetic stirrer kit and have been using the "Chlorine Only" tube with the magnetic stirrer. Is this OK?
    Pool Owner since Sept. 2014, but 2012(ish) in-ground pool. 40'x'20x3'(shallow)-8'(deep). Around 28,000 gallons. Vinyl liner. SWG. Aqua Rite with Hayward T-15 cell. Hayward Super Pump (self priming). Hayward Sand Filter. AquaPro Pro1100e Heat Pump. 2 main drains. 2 skimmers. 2 jets. 1 light. 1 diving board. Dolphin M4. TF-100 Test Kit.
    30,426
    Re: TF-100..."Chlorine Only" Tube
    It's fine to use the magnetic stirrer in it. The "chlorine only" cylinder is there for a very benign reason. Over time, the FAS/DPD test will start to leave a dark residual on the sides of the cylinder. By using only one, you keep the other one clean for all the other tests.
    It takes quite a while for the cylinder to darken. It doesn't affect the validity of the test but if it bugs you, it is readily cleaned with a 1:1 dilution of muriatic acid.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    If you're careful with the arrangement, you can get the speedstir, the cylinder that came with it, and extra stirbars all in the same case. That leaves one cylinder for FC, one for TA, one for CH, and the mixing bottle for CYA fits on the speedstir, too.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    This is good to know that the tube can be cleaned. I didnt know! I figured I would have to buy a new tube! Thanks for the info Dave!
    Divin Dave,
    Saturn94's Avatar
    Mar 2015
    Virginia
    500
    Interesting. I've been using the tube that came with my Taylor k-1515 FAS DPD kit for about 10 years and the tube is still clear as new.
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
