Results 1 to 8 of 8
Thread: Newbie needs help with the TFPC method
    May 2015
    Mississauga
    29
    Hi.
    So I am new to this method. My ex used to take care of the water chemistry but now it's up to me. My pool is a vinyl liner irregular shaped pool. My pool people hooked up my automatic chlorinator which I wNt to disconnect. So I tested my water today and here are my numbers.
    CYA 90 ppm. PH is 7.4. FC is 8.5 ppm. TA is 120. I am not sure what the goals for my pool should be and what I sgould be doing with these numbers today.
    Please help!
    P.S. Pool holds 43500 litres.
    Jun 2014
    14,970
    Re: Newbie needs help with the TFPC method
    Welcome Ziggygal. A couple things that I noticed right away ......
    1 - What test kit are you using?
    2 - "IF" we were to assume your test numbers are accurate (we never assume at TFP , a CYA of 90 is very high. Definitely do not use any chlorine products other than liquid bleach.
    So much depends on your test though, and what test kit you are using. Your reply will determine the next few responses. Welcome again!
    JoyfulNoise's Avatar
    May 2015
    13,171
    Welcome
    In order to practice the TFPC Method, you're going to need one of the Recommended Test Kits
    You are going to have to stop using pool stores and "pool people".
    You need to remove and throw away all the chlorine pucks in your inline chlorinator and just go to manually adding bleach to your pool.
    You also need to develop a daily and weekly pool care plan because a pool is not something you fiddle with once per week and expect to stay clean and clear.
    You need to update your signature with all of your pool details.
    As for your current numbers, assuming they are reliable, everything looks ok except your CYA is way too high for a vinyl pool and it is likely greater than 90ppm unless you measured that number yourself. Your CYA should be 30-50ppm with a target FC of 3-5ppm.
    Here are the Recommended Ranges
    Here is the Chlorine/CYA Chart
    If you need to do calculations for chemicals and figure out what to add, use PoolMath
    And, if you are confused by anything or need help, ask lots of questions as we are all over-achievers when it comes to being helpful
    Matt
    May 2015
    Mississauga
    29
    Thanks! I knew the CYA was high. I used the Taylor fAS-DpD K2006c test kit. So I am going to disconnect the chlorinator. I have liquid bleach. That is how my ex would add chlorine. As much as I hate to admit this he kept our pool water really balanced.
    Jun 2014
    14,970
    Well.... now, I'm confident that with a good test kit and TFP you will do just as good maintaining your pool if not better. Good luck and let us know if you ever need any help. We're all just a "click" away ... unless we're swimming.
    May 2015
    13,171
    It's not super critical but you should add lowering your TA to the list of To Do's BUT ONLY AFTER you get your CYA and FC perfected and you have an established pool care routine.
    Matt
    i_hate_pools's Avatar
    May 2015
    coal city il
    25
    Quote Originally Posted by ziggygal View Post
    Your ex may have kept the water clean but it wasnt "balanced". once the cya gets out of control (chlorinator keeps adding it when using pucks) trouble is a brewin' and it aint easy to keep clean no more. The amount of chlorine to maintain a pool increases with cya and you have too much. Got to have some but not too much. As others stated follow the cya/chlorine chart. Also if you have a mineral cartridge in that chlorinator gut it!
    May 2015
    Mississauga
    29
    Thanks for all your help!
