Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Help Hayward H100D Propane not igniting
    May 2015
    Rumford, RI
    13
    My heater for whatever reason will no longer ignite. The ignition does spark and I smell gas so assume the gas valve is opening but no ignition as the blow is only blowing cold. Please help on where i should look next. Below is what I have checked. I have 100ilb propane tank and it is about 1/4 to 1/2 full.
    Ignition does spark.
    120V to Xformer and 24v from Xformer to Gas Valve on/off switch.
    All Tubes are clean and clear of derbies.
    Help!!!
    Jun 2012
    western NY
    1,560
    Re: Help Hayward H100D Propane not igniting
    Well, you need three things for fire. Air, Ignition and Fuel. Since we can assume you have spark as you indicated you did, it can only be one of the other two. If the blower is blowing and it is moving air then that only leaves fuel. Are you sure all the orifices are clear at the front of the burner tubes? This is where the spiders like to build nests
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Quote Originally Posted by danpik
    +1. This is where I would focus my search.
    May 2015
    Rumford, RI
    13
    I will remove and double check. Just be sure below is where I am focusing? Red arrows are pointing to area?
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    A little hard to tell from the pic, but if the arrows are pointing at the burner tubes, that's one place to check. Another place to check is the pilot tube. There should be a small access hole in the pilot tube. Use compressed air at between 20-30 PSI to clean those out. Avoid using needles or similar objects to clean these out. Can use one of those compressed air canisters used to clean computer keyboards and the like. If you go with the compressed air canisters, find one with a needle-extender (looks like a small straw). Most should have this.
    May 2015
    Rumford, RI
    13
    Yes the arrow point to the gas ports that insert into the tubes. I will clean both to be safe.
    andyrob2215's Avatar
    May 2014
    Portage, Indiana
    127
    I'm in a similar situation but I am not getting any spark.
    I have read in your situation if you cannot get it working after you clean it, there is a gas adjustment screw that could be adjusted if absolutely necessary. But only if you are comfortable doing so.
    21'x52 AGP 11200 Gal
    TFPC Method
    May 2014
    Portage, Indiana
    127
    Also, where did you get those detailed pictures?
    TFPC Method
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Quote Originally Posted by andyrob2215 View Post
    In all of my years I have rarely ever needed to adjust the gas valve on a heater because it wouldn't light. Now I have made adjustments to a regulator as it wasn't supplying enough gas but even that is on the rare side as well.
    Unless you have the proper equipment to measure the gas flow you shouldn't be touching anything in regards to the flow of gas.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    May 2015
    Rumford, RI
    13
    Quote Originally Posted by ps0303 View Post
    I got Pic's from on line. Just Googled H1001d PDF. Also I am not comfortable or knowledged enough to try to adjust the gas especially since it worked last week. I will disassemble and clean again looking for the pilot pin hole.
    Jun 2012
    western NY
    1,560
    Please don't offer advice like this. I have been in the home heating repair business for almost 40 years and in all that time, working on furnaces, boilers and pool heaters I have only adjusted one or two gas valves (Not counting Pilot Adjustments) and I suspect that these were all due to someone else messing with them prior to my working on them. Gas valves have no user serviceable parts and for the most part are fairly reliable. If the unit is not working properly there is most likely an underlying, simple, reason. You just need to find it. In the case of the OP's heater, If there is spark, then the safeties are all being satisfied. This also means that the blower is functioning properly as there is a vacuum switch in the safety loop to verify air flow. This only leaves fuel flow. If he is smelling propane as he indicated he is, my suspicion is that the burner orifices are not letting gas flow into the burner tubes
    May 2014
    Portage, Indiana
    127
    The only reason I mentioned it is because I read in another forum where 10-15 people did this (not saying it's right) and it fixed, or at least made it work, for them. But I'm certainly no expert so I will not advise anything I'm not 100% sure on.
    TFPC Method
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    We just want everyone here to be safe. We do appreciate everyone's input into problem solving, we just need to be careful on the solutions we provide.
    Paul
    May 2014
    Portage, Indiana
    127
    I understand 👍
    In case anyone was wondering about my situation about not getting spark I went ahead and used the advice given and re-soldered the pins in the ignition module. And low and behold, success!! Every time I've tried it since then it has worked like a charm.
    TFPC Method
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    I understand ��
    Yep that is one of the issues I encounter from time to time on older units.
    Paul
    May 2015
    Rumford, RI
    13
    Finally the rain stopped enough for me to remove and clean. Everything seems clean now it appear to have 1 of the 8 ports clogged. I'll put back in tomorrow please just confirm this is where i was to look and clean.
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    Hi Everyone, I strongly recommend not adjusting the gas valve. The H100 burns 100,000 btu's an hour. A 100lb tank at half full may not be enough fuel. We have missed putting a Manometer on the incoming side of the gas valve to see static gas pressure with the valve closed and what it reads when the valve opens. This is from the manual
    The incoming gas pressure must not exceed 13.5 W.C. for propane and no lower than 3.0 W.C. The manifold side when the valve opens should be 2. Do not adjust the gas valve if the incoming gas pressure is low.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    I would never suggest a homeowner adjust a gas valve and I purposely don't mention a monometer as most homeowners don't own one and also it would require the homeowner to remove the screw from the gas valve. I feel it's best to have the owner get a licensed tech over to the house for that part.
    Paul
    May 2015
    Rumford, RI
    13
    So the outcome was great I reinstalled all and perfect!!!! Pool went from 67 to 87 in 91/2 hours!!!! Thanks Everyone for your help. Last question. I also can run with a reg 20lb tank and it worked well ( 67-87 was off a 100lb tank). Can I run 2 50lb tank vs 100lb tank?
  20. Back To Top    #20
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Yes you can run two 50lb tanks connected together.
    Paul
