Thread: Metal Corrosion Index
    Aug 2014
    Shallotte, NC
    693
    OK, I started a new thread because I wanted to distance this discussion from the current thread on CH and CSI. I'm going to go out on a limb and say there is *something* you can do to cause a lot more corrosion than your peers. I don't know what that is, but I have anecdotal evidence.
    I ran a machine shop up until about 15 years ago. I had all of the machine work for all of the electric motor repair shops in town and got to see a LOT of pool pumps, in season. At the time I knew absolutely nothing about pool chemistry, except I knew pools used chlorine, because I could smell it....
    Some pool pumps were regular visitors in my shop, where the shaft seal surface had corroded/eroded and some had failed bearings due to corrosion and subsequent damage to the bearing, shaft, or endbell surfaces. Some of these pumps showed up much more frequently than others.
    I've always wondered what some people were doing right and some people were doing all wrong?
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: Metal Corrosion Index
    I wonder if the ones that failed more often were dumping powdered shock in the skimmer causing the pump to frequently see high chlorine and low ph.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Aug 2014
    Shallotte, NC
    693
    Knowing what I know, now.... that sounds very likely.
