Results 1 to 7 of 7
Thread: Light at the end of the tunnel...Switching to BBB method Question
    Newpoolcrazy's Avatar
    May 2015
    La Porte, TX
    104
    Cool Light at the end of the tunnel...Switching to BBB method Question
    So we drained the pool about 3 inches because it was supposed to rain that much and I thought I could stand to lose another 3 or 4ppm, as per CYA/FC chart. So of course it hasn't rained yet. But that's great for the people who were flooding so I'm not complaining!
    So I'm looking for 6% bleach and all the Clorox is Concentrated. The generic bleach I got was 6.0% Sodium Hyd 94% "other" with a total of 5.7% available chlorine and 0 phosphorus. I thought we were supposed to use 6% and now all I see is 8.25% which is the concentrated stuff. Is one better than the other or do we just dilute one more?
    Also if I go to bleach now but still have other chemicals like ash and dry acid, can we still use it until it's gone and then switch? In other words is there an interaction between BBB and pools store chemicals that could cause a problem?
    I feel like I just missed a curve ball.
    No need to post my numbers now, they're all good according to pool math and Tk2006 kit. Just trying to get ready now that the weather's going to be more normal. And I really want to start get going with bleach!
    Thanks for any advice.
    Cornelius Monterey Steel/Resin AG 18' round (approx. 7600+gallons) Hayward veri-flo SWG w/sand filter.Testing w/ TK2006 using Speed stir.
    Jun 2014
    15,103
    Re: Light at the end of the tunnel...Switching to BBB method Question
    As a fellow Texan, I can tell you that any of the liquid bleaches you get at Wal-Mart or HEB is fine. I bought some generic stuff at HEB today. Either percentage will work. There are even some at 10 or 12%. All that does is means some may be more effective that others. But the PoolMath Calculator (in my link below) allows you to select which type you are using. No need to use any other products right now, although for acid specifically, liquid or dry is fine. Although dry has to be diluted before applying. If you have any old stuff or items from a pool store laying around, chances are you won't need them. Just stick to what the Poolmath Calculators shows you. Right now, regular bleach is your pool's best friend. Of course, ask us anytime you need assistance.
    PS ~ Here come the T-storms again!
    30,419
    8.25% bleach is absolutely fine. No problems.
    Not posting your numbers pretty much leaves us in the dark as to providing any guidance.
    Jun 2014
    Michigan
    62
    Been thinking of installing a float switch on my drain pump for just such an issue.
    I switched to BBB last year and the old chemicals are collecting dust. Opened the pool up this year and $17 dollars later she is almost perfect. I did have a low PH but adjusted that from 7.0 to 7.5 by turning one of the water jets up for more aeration. Bought some powder dishwasher soap and cleaned the filter's.
    20K gal, Fiberglass, 1.5 hp Century Pump, Sta-Rit System 3 Model PLM-100, 100 SQ Foot. Inline Frogger Chlorinater Mineral pack removed, adjusted the Chlorine pac to put in my own when on vacation. Liquid Pool Sanitizer,, BBB style.
    May 2015
    La Porte, TX
    104
    That's ok. I'm trying to use the tools provided here and ask as little questions as possible. I usually learn better when I throw myself into the deep end. Ok, pun intended.
    Jun 2014
    15,103
    Remember .... questions are encouraged.
    May 2015
    La Porte, TX
    104
    Thanks, Splash! Ok so I just adjust bleach % in the pool math and it'll work regardless. Yay!
    Skies are dark here too. Stay dry...unless you're swimming on puprose!
    Quote Originally Posted by Texas Splash View Post
    Don't worry. This was far from my last question.
    Thanks so much.
