Results 1 to 9 of 9
Thread: Minor leak at control valve joint
    Apr 2015
    Charlotte, NC
    19
    Thumbs up Minor leak at control valve joint
    I've noticed that I have a pinhole leak at a joint under the sand filter's control valve. It's minor enough that it releases a drop every minute or so. Is this something I can put something over and be done with, or is it going to require a nightmare teardown?
    10,000-gallon inground pool, Jet Black PebbleTec / plaster
    Hayward S244S Sand Filter
    Hayward Super Pump, 2 HP
    Hayward AquaRite AQR9 / T-CELL-9 ECG
    Polaris 360
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: Minor leak at control valve joint
    If you have unions on all those lines, it shouldn't be horrible. Does that fitting screw in? It looks like it might, but not 100% certain. If it doesn't screw in replacing it may be the easiest viable option. Personally I wouldn't bother with it unless you are bored, tearing into the piping anyway, or it just really annoys you.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    That's some pretty impressive looking stuff.
    Apr 2015
    Charlotte, NC
    19
    I was thinking about covering it with some epoxy. Just ordered some Plast-aid from Amazon. Had never heard of it. Seems like it might be a safer choice since it sets faster than epoxy. Thanks for the suggestion.
    Polaris 360
    Jul 2013
    Fletcher, OK
    3,353
    exactly what I thought, and the fact it worked made it even better
    Apr 2015
    Charlotte, NC
    19
    I used the Plast-aid yesterday (finally). It was a bit difficult to work with, because it's not smooth. Probably the main difficulty was the awkward location. But in any case, it's not leaking anymore, so problem solved. I'm pretty sure epoxy would have worked well also.
    One note--that Plast-aid must be horrifically smelly. I was wearing a respirator with organic vapor filters (the same one I use when handling muriatic acid), and I could still smell the Plast-aid a little bit.
    There have been a couple idiots that leaned on my plumbing recently, including right on the control valve. (Apparently, plastic and PVC are easily confused with iron railings.) At the time, I didn't say anything, because I thought I was overreacting. I'm not going to hold back anymore, because I am now wondering if the flexing and stress they put on the joints caused this little leak. A little hairline crack or pinhole is all it takes.
    Polaris 360
    Jul 2013
    Fletcher, OK
    3,353
    That is great, I am glad it worked and no more leak
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    That's the same kind of jackass that will lean on a brand new car. Hey a-hole! Move along!
