Results 1 to 8 of 8
Thread: Pump won't prime and water is coming out of air pressure release
    May 2015
    Littleton, Co
    5
    Our pump was working delightfully for the last couple of weeks - I even vacuumed the pool successfully and we've been backwashing regularly without problems. Today, the pump won't prime. I can't find any leaks anywhere When I tried the air pressure release on the pump, water started pouring out of it. Usually, I either hear a rush of air or nothing. I've never seen this. What on earth? Has anyone ever seen this?
    Thanks!
    Above ground pool 36,000 gallons, 14x36 and 16' wide and occasionally the bane of my existence. We have a sand filter and a Hayward pump. We live in Colorado so our swimming season is quite short. We try to extend it with a solar blanket.
    Jun 2014
    15,068
    Re: Pump won't prime and water is coming out of air pressure release
    Is there any chance you might have sucked-up something into your return (suction side) from your last vacuum session?
    May 2015
    Littleton, Co
    5
    Quote Originally Posted by Texas Splash View Post
    Does that mean I should check the skimmer side?
    Thanks for replying, by the way
    Jun 2014
    15,068
    That's what I was wondering. If by some chance, while vacuuming, something got sucked-up into your suction line under ground that goes to your pump and pump basket. Just a thought. Stranger things have happened. With that line plugged or obstructed, it might explain why you aren't getting any water at all to the pump area.
    30,415
    ctpdenver,
    Welcome to the forum.
    What is your current psi - pump running?
    Is it the same as before this happened?
    May 2015
    Littleton, Co
    5
    Hey everyone - thank you so much - something was stuck in the suction line underground. After much effort and some inappropriate language, we finally got it fixed. Thank you for your help. I really appreciate it.
    Great forum.
    Jun 2014
    15,068
    Good language comes through again! Yippee! Enjoy.
    May 2015
    Littleton, Co
    5
    I was talking up this forum something fierce last night.
